2016 EMC Vintage class heavy on Y Block entries
Posted By RB 10 Years Ago
Rated 2 stars based on 1 vote.
Small block
Posted 10 Years Ago
Posts: 90, Visits: 2.5K
Yes   I guess that would be a closer fit,  nice to see a different engine I like your choice.
Posted 10 Years Ago
Last Active: 42 minutes ago
Congrats goes to all the competitors in all the Engine Masters Challenge classes.  The only losers would be the ones that don’t go to the trouble to submit an entry in one of the engine classes that are available.  Giant Kudos goes to Royce for bringing three engines to the competition.  That was impressive as he was also dealing with three different engine families.  Because of time constraints, Royce was not able to dyno test the MEL (Edsel) engine before bringing it and it had a simple bolt failure at the rocker arms once it was put under a dyno load at the UNOH.  That engine on its only good pull sounded great and the numbers are very stout.  Lots of potential there for sure.
While previous years’ entries were good in recapping my expenses by selling or repurposing the engine, it didn’t lend itself towards being a top contender.  For this years’ entry, I took a different approach to the overall combination.  This years’ combination was built more specific to the EMC competiton which meant using parts that make the engine less sellable without major reconfiguring.  As usual, this competition makes one think way outside their comfort zone but all the learnings do enventually get passed along into future engine builds.  This year had a number of new revelations in what it takes to get those good scores at the EMC.  Special thanks to all that contributed funds and/or time to make this years’ engine a solid winner.
While this particular sheet doesn’t show a 600+HP number, it does give you a good indication of what the torque values on this years’ Y entry do look like when setting the engine up for a good points score.
http://forums.y-blocksforever.com/uploads/images/25e1b224-1a9f-4c6a-87ef-4fb2.jpg
Talkwrench
Posted 10 Years Ago
Posts: 898, Visits: 23.2K
http://forums.y-blocksforever.com/uploads/images/9cfea02b-adde-4e22-ba79-ab90.jpg
John Mummert
Posted 10 Years Ago
Posts: 919, Visits: 7.5K
http://forums.y-blocksforever.com/uploads/images/ae7539b6-3e42-4fb2-862b-a954.jpgEMC  2016  is in the history books. It was a good time had by all.  Ted held up the Y block 2-0 Vintage class victory.  We all can hold our heads high for another year, this time with a cylinder head,manifold package that is more agreeable to the Y-Blocker.
 The Mummert  build came about this year with many different reasons in mind and EMC wasn't the first on the list, but was a consideration being pondered.  As stated earlier in this post the new manifold was supposed to be done earlier in the year and get tested on the new 355 cu/in motor being raced in the falcon.  The 343in had been running in John Hildebrands 31' coupe and weren't wanting to yank it out of the car to replace that manifold dyno test it, just to take the manifold back off and get prepped to put it back in the car, because the coupe has so much engine set back that the tunnel ram won't fit without cutting up the car.
 Having many of the parts for the 331cu/in motor on the shelf the decision was made to get it running again.  A running engine was worth more than a shelf full of parts and it would give us more latitude to do manifold testing or EMC and not have to pull one of the race cars apart.
 Once we had decided to enter the competition we knew the work load in the shop was going to get harder,  it  now had to more than a good dyno mule it was going to have to be a competitive EMC entry. We had to call on John Hildebrand and Todd Ferguson to help us out. This engine would not have been possible without everyone rolling up their sleeves.
 Having competed in the EMC in 2002 we had some good knowledge of what we wanted to do,  but much of this information was 14 years old so we knew we would have some catching up to do as this competition has gotten more competitive every year.
 The  bottom end of the engine is comprised of a B9AE block, bored to 3.84".  The block was tapped for screw in freeze plugs  and 1/2 filled with Embeco.  The crank is a C1TE  steel truck crank. ( seeing the part number on the crank did give some inspiration) It was offset ground to 3.57" 1.889" honda journal, nitrided  and undercut outer counterweights 53lb ready to run.  ARP main studs with factory main caps deburred and shot peened. Molnar 6.125" rods with Race-tec  pistons.   The original pistons were set up with 10cc domes.  Looking at technology through the year we decided to reshape the dome to a 4cc finished size and reduce the combustion chamber down to 49cc.
 After pondering right up until we made the phone call  the camshaft  ordered was 248@.050" .345" lobe lift ball nose grind on the intake and 247@.050"  .337" lobe lift, on a 104 lobe center.  With the start  rpm raised to 3500rpm  the cam was installed straight up at 104.  (In 2002 we ran a 106 installed on a 100, but we were starting at 2500 rpm.)  I think I would advance it some or reduce the intake duration a tick, doing it over again, hind sight is always 20-20.  Trend tool steel lifters, and  Smith Bros pushrods
 Oiling duties were left to an OEM ford gerotor pump.  The idea was to use this engine to try a direct AB test on the two styles of oil pumps available to see if there was any measurable power difference between them. After researching it more we decided to build a better gerotor. Dual inlet feeds and adjustable external bypass was the surest method to reduce aeration, raising the quality of the oil entering the engine. It would also raise the efficiency providing a more linear flow allowing good low speed oil pressure without having to run to much pressure at high speed. (We may have over thought this, but it did work well and looked good doing it.)   The marine oil pan made perfect sense for us. It has large capacity, built in windage tray, fits our short timing cover, and fits just about nothing but a boat or a dyno.  Still never got to AB the two styles of oil pump.
   The top end of the engine was really the easiest part. The head gaskets are OEM steel shim units. Mainly to reduce the dead area around the bore an raise the combustion quality.  Deck height was set to .015" .  The cylinder heads are our angle mill CNC race heads milled to 49cc.  The rocker arms are 1.7 Mummert roller rocker assemblies.  New Tunnel ram intake  topped off by C&J modded 650 double pumpers. and R2C velocity stacks.
  Headers are 15/8 to 13/4  built to fit the F-100.
  We were very pleased with the performance of the engine generating 100hp/litre @6400rpm while still making good low and mid power.  However the score is what matters in EMC competition,  and we have to pick up some grunt in the first 1000 rpm. We may take it to the dyno and see if a few tweaks get it headed in the right direction.
  I really enjoyed meeting everybody.  We may do it again if John is up for it, but for now its time to go back to work.
           Geoff Mummert
http://ford-y-block.com
speedpro56
Posted 10 Years Ago
Posts: 1.3K, Visits: 9.2K
Fantastic job for sure and your hard work is much appreciated ( John and Geoff ). A job well done!
-Gary Burnette-
Posted 10 Years Ago
Geoff.  Thanks much for the summary on the EMC engine you entered.  That little engine is indeed a powerhouse.  Congrats on the high points finish your team put up on the board.  The win with my engine could not have happened without the work you had done on the heads and likewise all the parts you provided.  Thanks for all that.
I’m in the process now of getting the various parameters on my engine for an upcoming YBM article.  I’ll be sending the blueprint sheet on the engine to the Hot Rod people for their article.  That engine was put together in a hurry and as such, I didn’t get a chance before the EMC to get all the documentation summarized.  There’s a clipboard of paperwork here I’ll have to go through and collate into something meaningful.
I will be putting this years’ EMC engine back together for a some additional header testing and to also see what the engine will do in a race day tuneup rather than for maximum scoring.  Once that’s done, that engine will be history and work on a Y engine that will hopefully jump up another level of performance will start.
Posted 10 Years Ago
Special thanks to the team members on my 2016 EMC team.  In the dyno room helping to make tuning changes to the engine were Jody Orsag, Fred Hertzog, and Steve Culp.  Others making this engine a success includes Joe D. Craine, Lonnie Putnam, and John and Geoff Mummert.  With all the Mummert parts involved, this could have easily been a Mummert entry.  Thanks also goes to Jon Kaase for technical advice and the loan of his headers from his 2015 EMC Y-Block winning entry.  Thanks guys.
http://forums.y-blocksforever.com/uploads/images/6d05a6b9-e3a2-449d-8cd7-2434.jpg
Y block Billy
Posted 10 Years Ago
Posts: 1.6K, Visits: 5.2K
Great job and hats off to all the guy's and efforts put in to to make our favorite engine stand out! And for a statement from Kasse that Y Blocks Rule is outstanding!
55 Vicky & customline
yalincoln
Posted 10 Years Ago
Last Active: 5 days ago
Posts: 382, Visits: 4.9K
great work everyone!!!!
Posted 10 Years Ago
Hot Rod has updated some of their links to reflect the 603.2 HP number that was run on the Eaton Balancing Y entry at the EMC.  Here are a couple of the links.
http://www.hotrod.com/articles/2016-amsoil-engine-masters-champions/
http://www.hotrod.com/articles/ford-y-block-takes-vintage-class-win-engine-masters-2016/
