exhaust manifold '55 Monterey
Posted By biffman 9 Years Ago
biffman
Question Posted 9 Years Ago
Posts: 5, Visits: 16
I've got a substantial crack and all opinions are to replace rather than weld.
The part number is EDB-8431-A and I just can't seem to find a used one.   Any chance the EDB-9431-A would work?   (I did come across one of those)   Or some other number?
stuey
Supercharged (851 reputation)Supercharged (851 reputation)Supercharged (851 reputation)Supercharged (851 reputation)Supercharged (851 reputation)Supercharged (851 reputation)Supercharged (851 reputation)Supercharged (851 reputation)Supercharged (851 reputation)
Posts: 440, Visits: 3.8K
Hi there
I'm guessing that casting number is really EDB-9431-A    I believe 9431 means LH exhaust manifold, 9430 means RH exhaust manifold.
http://www.y-block.info/casting/exhaust.html
There are one or two on e-pay but check carefully as some are cracked and/or welded.
Depending on where the crack is I would grind out with a burr and braze using a pre heat and a slow cool.
I would think someone on the forum might be able to help.
Why are there lots of  9431  but never  any  9430?
stuey
carl
Posts: 1.2K, Visits: 20.6K
biffman (5/3/2016)
I might have a EDB- 9431-  A  manifold,i will check what I have and let you know  Carl
biffman
Thanks Carl, let me know.
biffman
Thanks Stuey!   I hope you're right about the part number, as that would make my life way easier.
carl
I checked my 55 Merc 292 today and it has ECH- 9431- A exhaust manifold,i am sure it is original.The EDB- 9431- A  manifold which is probably a 56 will work for you though  Carl
biffman
thanks for checking!~
