Visits: 2.7K
Im ordering parts to rebuild my holley to reinstall it on my '56. Problem is though 30 plus years ago when this carb and manifold was removed for a '62 model with a 2100 2v, some parts are missing.
First off im trying to source a fuel filter spring as the spring and filter is missing.
I'm also trying to find the fitting that goes into the back of the carb on the manifold vacuum port. I need the one that has two ports one for the outter distributor advance can and another for the double action fuel pump vacuum line.
Does anyone know where I can find theses parts or a part number or even a part that will work the same?
Posts: 7.5K,
Visits: 205.8K
I do have the dual inlet brass fittings for the back of the ’56 4V carbs. Pretty sure I can also dig up the filter screen and associated spring but will have to dig deeper for those. If you’ll send me your shipping address via email, I’ll get what I have out to you. My email address is located under the contact information at www.eatonbalancing.com .
Visits: 2.7K
Thanks Ted, i sent a email. Let me know how much you want for thoses parts.
