1956 Air cooled tranny torque converter needed
Posted By Town Vicky 10 Years Ago
Posted 10 Years Ago
IMO a crack in a two piece FordoMatic torque converter would be an unusual event.
The FordoMatic aluminum air cooled torque converter is a two piece unit sealed by a rope type gasket.  IF your converter is leaking, I would suspect the two piece converter gasket is the source.  Another thing to check is whether the two drain plugs on the torque converter housing are tight.  -IF someone drained the converter previously for a fluid change, it's possible they did not tighten them adequately.  I ran into this a hundred years ago on a Buick Dynaflow transmission torque converter.  -The leaking transmission was in fact the leaking torque converter drain plugs!   Hehe
IF you separate the two piece converter to clean the inside and change the gasket, check to make sure the factory markings for the two housings are properly aligned as original.  I've only worked on two of the air cooled FordoMatic torque converters, but on both of those the witness marks were not aligned by the previous person that had the unit apart.  -This is a balance thing.
Hope this helps.   Smile
carl
Posted 10 Years Ago
Posts: 1.2K, Visits: 20.7K
I have one,where are you located.I am in central Ohio    Carl
EDHYBLOCKER
Posted 10 Years Ago
Supercharged (76 reputation)Supercharged (76 reputation)Supercharged (76 reputation)Supercharged (76 reputation)Supercharged (76 reputation)Supercharged (76 reputation)Supercharged (76 reputation)Supercharged (76 reputation)Supercharged (76 reputation)
Posts: 30, Visits: 274
I have a good one pulled last year from good working tranny, both available. Live in CA.
Gary 916-717-1520
Town Vicky
Posted 10 Years Ago
Supercharged (181 reputation)Supercharged (181 reputation)Supercharged (181 reputation)Supercharged (181 reputation)Supercharged (181 reputation)Supercharged (181 reputation)Supercharged (181 reputation)Supercharged (181 reputation)Supercharged (181 reputation)
Posts: 107, Visits: 3.5K
I need the complete converter the one I have leaks and I thing it has a crack
Posted 10 Years Ago
Hmmmm...  Do you actually need the converter itself or just a replacement hub or ring gear?
Town Vicky
Posted 10 Years Ago
Looking for a good 56 car Ford-o-matic air cooled converter
