Posts: 1.6K,
Visits: 5.2K
This is the Hot Rod version which I got a couple copies of, I also got a copy of Hot Rod deluxe which has a Picture of Tim mcMasters FED along with a Pic of Royces Mercury and not sure but think its Larry Shorts 56 gasser! So if I am not mistaken there is another Engine masters magazine with coverage that I am missing??? will have to do some searching!
Correct, there is an Engine Master's Magazine, Spring issue and a Hot Rod Magazine, April issue, both with the Kaase Y Block on the cover. Different pictures of the engine, though. Engine Masters is quarterly so it should be on shelves for a while.
Last Active: 2 Weeks Ago
It's fun to read all about the different engines and having no dog in the hunt to me it could be better reading and seeing if all the engines conformed to the same or at least similar rules. Examples. Single carb, no electronic or mechanical fuel injections, ignition must be powered at the stock location(no crank triggers), no electric water pumps, cylinder head port arrangement must remain stock for engine as manufactured (intake and exhaust). Hey it's just what I see.
Visits: 1.1K
I've read the rules posted online, which I read as the actual engines that competed last year can't be re-entered again this year, but not Y blocks in general. I wonder if anyone will be brave enough to enter the Y into the small block class? I'll try to post the link.
