Visits: 2.4K
When I bought my Fairlane, all the ignition wires were way too long and laying on the manifolds, some burned. I removed them and then removed the distributor cap, making note on the firewall where the rotor faced so I'd remember to put everything back together properly. Then I removed the distributor for rebuilding. So far so good. Holidays arrived and nothing got accomplished. Grandson stayed with us awhile and wanted to help with the car, so I had him clean and sand the firewall for paint (see where this is going?). Well, it wasn't until I had finished the painting that I remembered that the mark is now GONE. In the interim, I bought new wires and the original type of wire routing hardware. I will next get some wire numbers once I start assembling this mess. OK, now, here's the question: How did the wires orient in the CAP when new (where was number 1)? My cap is unmarked. To assemble this stuff, I'll begin by installing the wires (correctly, I hope) on each plug and then work my way back thru the wire holders, then to the distributor. I can figure out the distributor to TDC. Any suggestions? Sorry for the long drawn out stuff Jim
Visits: 497.8K
I think the first thing you want to do is to insert the distributor into the engine and orient it so you have room to move the distributor for retard/advance without interference with the intake. I checked my distributor and looking at the distributor from the passenger side, number one is down and to the left a little. It lines up closely to the bottom clip.
The suggestion I would make is to get those little doohickey/s that go on the wires that have the #'s on them. Put one at the distributor end, the other at the plug end.
Last Active: 4 hours ago
Visits: 38.5K
Visits: 2.4K
Hi Paul & Moon Thanks so much. The diaphram hitting the firewall is a good thought Jim
Visits: 102.7K
After a lot of trials - I ended up with this basic orientation of the plug wires - trying to get the lengths to work out. The plan being to end up with the engine at the initial timing mark - and the number 1 plug wire right at the front. This diagram is drawn as if the carb would be at the top center of the page. On mine the vacuum pot has been located with the inlet nipple pointing roughly at the center of the carb. All of this takes some artful adjustment of the gear tooth engagement - trial and error.
Steve Metzger Tucson, Arizona
Visits: 2.4K
Thankyou also, Greenbird. As I'm using the original double diaphram distributor now, I've also purchased the needed metal vacuum lines (pre bent, and hopefully correct), and will attempt to use them to assist in the distributor positioning when I get to it. Right now I'm in the process of replacing the front cross member, then I can begin reassembly of this thing. I need some good weather. You guys are all so helpful. I really appreciate it. Regards Jim
Visits: 23.2K
Visits: 2.4K
Hey Talk How are you doing down under as I recall? You probably have much better weather there Jim
