Thunderbird trans swap
Posted By EDHYBLOCKER 10 Years Ago
EDHYBLOCKER
Question Posted 10 Years Ago
Supercharged (76 reputation)Supercharged (76 reputation)Supercharged (76 reputation)Supercharged (76 reputation)Supercharged (76 reputation)Supercharged (76 reputation)Supercharged (76 reputation)Supercharged (76 reputation)Supercharged (76 reputation)
Posts: 30, Visits: 274
I have 57 tbird building 312 now. .60 over ,G heads, domed mummert pistons and rods. Looking to convert my stock auto tranny to a manual 4 speed. Not sure what all is needed, have original rear end rebuilt and in car and wish to keep that. I am looking for a good blend of low end and low rpm at freeway speed. Any help is welcome thanks.
Gary
Posted 10 Years Ago
Posts: 3.7K, Visits: 498.3K
You will need the clutch pedal assembly as well as the clutch linkage from the pedal to the clutch throw-out arm.
If your going to a manual trans, go to a 5 speed.  Probably just as much trouble as a toploader and you get the benefit of an O/D
EDHYBLOCKER
Posted 10 Years Ago
Thanks Paul what 5 speed would be preferable?
Gary
Rowen
Posted 10 Years Ago
Posts: 435, Visits: 29.3K
EDHYBLOCKER, don't mean to cut in but John mummerts site says 93 or older mustang. I am not sure if that is for his adaptor kit or a general ease of fitment
Rowen
Rowen
55CV
Woodland, Ca
Posted 10 Years Ago
Welcome to the site, Gary.
Like Paul, I'd encourage you to consider a 5 speed trans. instead of a 4 speed.  The extra gear will give you improved drive-ability and increased driving enjoyment.  For what you're putting together, I'd suggest using a T-5.  That said, there are some significant differences in the T-5s that have been produced over the past 30+ years and what is available today from TREMEC.
Modern Driveline has some helpful information about T-5s on their web site.
Click the links below to see a history of the Borg Warner T-5's development . . .
http://www.moderndriveline.com/Technical_Bits/t5_history.htm
IF you're interested in a T-5z after reading the above, look at Modern DriveLines stock number MD-552-0251.  Notice that MDL offers different overdrive ratios to their customers.  Consider their optional .73 overdrive ratio offering instead of going with the .63 factory TREMEC o/d ratio.  I think you'll like the final drive ratio in your 'Bird with 3.56 rear gears in the rear end.
Click the link below to see Modern DriveLine's T-5z offering . . .
http://www.safepay.net/cgi-bin/shop/cart.cgi?db=mddata.txt&category=Transmission&merchant=moderndriveline
John Mummert has the adapter you'd need to put the T-5 behind your y-block.  John also has the clutch, pressure plate, throw-out bearing and pilot bearing you might want to use.  I suspect that someone on our Forum can connect you with the 'Bird clutch linkage, y-block bell housing and flywheel you'll need for the conversion.
JM's T-5 passenger car & 'Bird web page can be clicked below . . .
http://www.ford-y-block.com/t5in-cars-bird.htm
Hope this helps.   Smile
EDHYBLOCKER
Posted 10 Years Ago
Charlie great options and thanks for taking the time and all the help. I think this is the direction I will be taking. Should get after it later in the year, still have the body off the frame completed working on the motor now.
Gary
Posted 10 Years Ago
Posts: 1.9K, Visits: 195.0K
I've got a T-5 in the bird, and a TKO500 in the roadster. Both came from D&D, the service was excellent. Depending on your location, shipping might be less. Both mine have the 2.95 low, and the .8 o/d. The bird has a 3.7? Dana 44. I think the suggestion of the .73 o/d is a good one.
http://www.ddperformance.com/aa251-tremec-t-5-5-speed-transmission-2-95-shd/
Posted 10 Years Ago
With a T5, for purely street use, you might be happier with the optional .73 od Modern Driveline have to offer.
For street / strip, go with the .63 od, because that allows you to run a shorter rear gear, which will be better for the strip, and preserve your mileage on the highway.
And depending on your cam choice, you may need a shorter rear gear just for everyday driving on the street, in which case the taller .63 od might also be better when you get on the highway.
Posted 10 Years Ago
charliemccraney (1/21/2016)
Charlie's recommendations are solid and I agree completely.  The camshaft you use in your 322 build and the 'Bird's intended use are pivotal considerations.  My focus is street driving, stop-and-go drive-ability, and throttle response.  With the displacement you've got you can certainly run something healthier than a stock de-tuned y-block replacement cam.  John Mummert will steer you appropriately in terms of LCA, duration, and overlap for your intended use.  While static compression ratio used to be the focus back in the day, I feel that dynamic compression ratio (when the intake valve closes), LCA, and final drive ratio are critical variables for street, stop-and-go, lower rpm crisp performance, enjoyment, and drive-ability.  I've seen too many vehicles that sound powerful but don't perform smoothly pulling away from the curb or in traffic.
Again, IF you're looking to do street AND strip, Charlie's recommendations will serve you very well, too.
EDHYBLOCKER
Posted 10 Years Ago
All great feedback and well appreciated...I was thinking the Isky 4 might be a good cam choice , has the mummert rods and domed pistons, 113 heads new seats and stainless valves.
Gary
