Visits: 21
Dennis Carpenter has brand new old stock cylinder heads for $99.95! I just got a pair and they are in original Ford packaging covered with Cosmo!one. I got 2 heads, eight intake and eight exhaust valves brand new for less that $400.00 including shipping! Anyone with worn out valve guides should snatch up a pair!
Visits: 29.3K
Seems a good deal, what are C3TZ-6049-G heads? Valve size? Hardened seats? Big/small ports? Thanks, Rowen
Rowen 55CV Woodland, Ca
Last Active: 4 Months Ago
Posts: 1.3K,
Visits: 9.2K
Don't believe their the performance heads but the small valves lower compression, still a bargain for what they are.
-Gary Burnette-
Last Active: 8 Months Ago
Posts: 3.3K,
Visits: 238.8K
If I recall, those NOS heads came out of S. America (?) some years ago. By the way, J. Mummert sells 1.84" intake valves that apparently fit those heads nicely. (that's bigger than 1956 intakes) And they can likely be milled some to bring up compression, although it would be a good idea to check the deck thickness before doing so. Don't know if the decks are posted? If so they can probably be milled quite a bit..
Visits: 1.7K
these are a cheap way to get a set of heads for a y block.for A stock enging they are just fine and thats covers more than 95% of y blocks on the road.
