Hydraulic lash adaptors too tight - leak from intake valves
Posted By slonny 10 Years Ago
slonny
Question Posted 10 Years Ago
Hitting on all eight cylinders (10 reputation)Hitting on all eight cylinders (10 reputation)Hitting on all eight cylinders (10 reputation)Hitting on all eight cylinders (10 reputation)Hitting on all eight cylinders (10 reputation)Hitting on all eight cylinders (10 reputation)Hitting on all eight cylinders (10 reputation)Hitting on all eight cylinders (10 reputation)Hitting on all eight cylinders (10 reputation)
Posts: 4, Visits: 14
Greetings,
My project bike is like an untamed horse, just doesn't want to give in. The bike is '91 Honda Nighthawk 750 with 34k miles. After running compression test on the bike I found out that the second cylinder had lower numbers than the rest. It happened to be a burned exhaust valve. New valve was ordered and the seat had been recut. Since the rest of the valves were in good condition, they were lapped.
After reassembly I did ignition timing test and synchronized the carbs. Most of the problems that were due to unsynchronized carbs went away. However, the bike continues to backfire on acceleration through the left exhaust pipe and through the carburetor on the first cylinder.
Leak down test revealed that cylinders 1 and 2 have leaking intake valves. There is no leak into adjacent cylinder, so the head gasket is good. The other two cylinders are in very good condition.
#1 - 50%
#2 - 45%
#3 - 12%
#4 - 10%
All the cylinders have uniform compression at WOT (130/130/135/140). Compression test was done on cold engine. Strangely enough numbers tend to decrease slightly when the engine is warm.
At first I thought that I may have messed on timing when I was putting on the cam chain. I have taken cams off again and did a leak down test on cold engine. All the valves are sealed and the percentage is within the green zone. 20% on the ones that were 12% when the engine was warm.
I have checked the cam timing prior to that. Everything was spot on. I reassembled everything and did the leak down test again. For some strange reason cylinder 2 and 4 are leaking out of intake valves. I have analyzed everything farther and it seems to me that hydraulic lash adapters are too tight. The lobes on the camshaft are pressing down on the lifters at TDC very slightly. I think lash adapters have to compensate for that, but they don't!
Hydraulic lash adapters are automatically adjusted. Any idea what the problem may be? All the parts were working fine before any engine work was done. Even with the burned out valve the bike was running smoothly.
Someone suggested that "grinding the seats may have allowed the valve stems to sit deeper into the head, beyond the range of the lash adjusters? You may be able to grind off the ends of the stems to compensate?"
Seems that this could have happened, but before I took the camshafts off for the second time cylinder 1 and 2 were the ones leaking. Now it is #4 and #2. Doesn't make any sense!
Here are some videos. If a picture is worth a million words, then a video is worth a billion!
http://youtu.be/YWZnvXt4Puw
http://youtu.be/zu5MBRIlBig
http://youtu.be/KRgEW-aUpFE
Thanks.
