Looking For A Working Fuel Gauge
Posted By Half-dude 11 Years Ago
Half-dude
Supercharged (603 reputation)Supercharged (603 reputation)Supercharged (603 reputation)Supercharged (603 reputation)Supercharged (603 reputation)Supercharged (603 reputation)Supercharged (603 reputation)Supercharged (603 reputation)Supercharged (603 reputation)
Last Active: 7 Months Ago
Posts: 229, Visits: 11.3K
Hey guys,
So my fuel gauge is reading E no matter what. I know the wiring is good as I've tested it with a volt meter, it has a new float and sender that has the correct 10 ohm rating. I'm guessing the original gauge must be had or seized from sitting for 18 years.
Does anyone know where I could get a replacement gauge for the original 6 volt system? Either an original or a aftermarket newly built one it doesn't matter to me just as long as it fits in the dashboard like the original.
Also, I know this isn't the tech forum but does anyone know if there's a way to test the old gauge to see if it's bad?
Posts: 3.7K, Visits: 498.3K
There is a repairer named Williamson's in Arkansas that repairs gauges if you can't find a replacement.
Check the old parts suppliers for a replacement.
Half-dude
Can I get Williamson's address or phone number?
Bobwanna
Supercharged (309 reputation)Supercharged (309 reputation)Supercharged (309 reputation)Supercharged (309 reputation)Supercharged (309 reputation)Supercharged (309 reputation)Supercharged (309 reputation)Supercharged (309 reputation)Supercharged (309 reputation)
Posts: 108, Visits: 5.8K
Looks like you have gone thru the basic test procedures. But just in case you would like to have another chance to test the gauge itself I have a 2 page scan from my 1955 Ford Car Shop Manual in .pdf format. This gives wiring details and test procedures. It gives a method to test the gauge only. If I have it correct a 3V battery(s) power applied to the 2 terminals should give you 1/2 gauge reading. For some reason I am not allowed to attached a .pdf document to this reply. I wish I knew how to post pdf stuff? Anyways, If I have your email address I would email it to you.  - Bob
AKA   Bob-93021
Half-dude
I actually have the physical shop manual, I just never noticed that it mentioned tests for the gauges, thanks!
www.williamsons.com
479-369-2551
Half-dude (10/17/2015)
mgcookwv
Supercharged (410 reputation)Supercharged (410 reputation)Supercharged (410 reputation)Supercharged (410 reputation)Supercharged (410 reputation)Supercharged (410 reputation)Supercharged (410 reputation)Supercharged (410 reputation)Supercharged (410 reputation)
Posts: 150, Visits: 283
I would like to have your pdf file for the fuel gauge as I have the same problem, I would appreciate a copy.
Thank you,
Mike Cook
mgcookiewv@outlook.com
Bobwanna
Mike, I just found your request for a pdf from the shop manual. I just sent a pdf to your email address. I hope this helps! - Bob
AKA   Bob-93021
mgcookwv
Been a while on this post, my email was and has been a problem , would you please resend to me the pdf file you have at mgcook1950@yahoo.com, I appreciate the guys on this forum are willing to help others.
lilbirds
First Time Poster
Posts: 1, Visits: 2
To check to see if gauge is working, simply disconnect wire at sending unit (yellow) and ground it with ignition turned to on or acc.  If gauge goes over to full mark after a few seconds, the gauge is fine, and the problem is either the sending unit or possibly the fuel tank itself not getting a good ground.  If gauge is bad, a 6 volt one from a t-bird should work, just might have to change out rear mounting plate.
