Visits: 31.8K
Anyone know the id size of the bypass hose on the 272 yblock water pump thanks
Visits: 14.3K
If your talking about the short hose from the water pump to the intake I used 5/8 heater hose on mine.
Durham Missouri
Last Active: 59 minutes ago
Posts: 3.6K,
Visits: 497.5K
Yep - 5/8. Just replaced mine
Visits: 31.8K
Thanks someone told me 1/2 inch I knew that was wrong
Posts: 1.8K,
Visits: 11.4K
55 GLASS TOP (10/8/2015)
Thanks someone told me 1/2 inch I knew that was wrong Yas theboys said, 5/8" x 3" long.
Posts: 2.0K,
Visits: 126.6K
Hey, didn't the very early Y blocks use 1/2" bypass tube? I thought I had removed one from a 239. Maybe my memory fails me though. 5/8" for just about all I've seen
