Randy.  I'm aware that you are 'efforting' to do a concourse restoration of your dad's F code '57.  I don't know which Ford assembly plant produced his car.
This information pertains to the Dearborn assembly plant only.  The information is reported in the 2001 Addendum section of the Classic Thunderbird Club International Restoration Details and Specifications Manual on page 236 as pertains to photo 26 on page 237...
"After January 1957 this type spin on oil filter (black) was installed on all 1957 model engines at the Dearborn assembly plant.  (This information obtained from original assembly plant photos)  Early 57 models had the 55/56 canister type oil filter.  The canister type oil filter housing is shown on page 177."
Turning to the above mentioned photo [1996 Addendum section] on page 177, information pertaining to photo 40 is given on page 176.  Again, this info pertains to the Dearborn assembly plant where the little 'Birds were built...
"The 1955, 1956 and very early 1957 models had the canister type oil filter.  The canister was painted black.  The decal was gold with a red border.  The lettering was black.  The decal was installed the length of the canister.  The canister gave way to the spin on filter sometime in January of 1957."
_______________________
Additional Dearborn assembly plant information is reported in the 2013 Addendum section on page 478 pertaining to photo 34 on page 479.
"Show(n) is the filter canister for the 1955/1956 models and early 1957 models.  Spin on filters for 1957 started mid Dec 1956.  These canisters are slowly disappearing because most are being replaced with a spin on filter which eliminates the canister."
Randy, I'm gathering that the use of spin on filters may have begun at different times at different Ford assembly plants.
Going back to page 236 as pertains to photo 27 on page 237...
"This type spin on oil filter was the original over the counter service part and appears to have been installed at some assembly plants, but there is no evidence of this type being installed at the Dearborn plant where the Thunderbirds were assembled."
NOTE:  Picture 27 shows a willow green (my take; '57 'Bird color) spin on oil filter with a silver [argent] (upper) and red (lower) band surrounding the filter base short of 1/2 way up the height. Red large FoMoCo lettering with a Genuine Parts banner under the FoMoCo on the silver [argent] upper 2/3s height area; red large lettering OIL FILTER (upper) and B7A-6731-A (lower) on silver background on the lower red 1/3 height area.  Probably of more significance is the sharp edge near the top of this green filter unit where it changes to a slightly convex top.  In comparison, the black filter apparently installed at the Dearborn plant has a top curvature like what is still used today at least by Fram.
Hope this helps.
