Visits: 97
I'm tearing down a 312 block and there is one piston that will not come out. I've tried hitting it out the top, the bottom. I've used a wood block, a steel chisel and lots of PB Blaster. The piston is in #2 cylinder and is at the TDC position. Any suggestions would be greatly appreciated.
Steve
Steve
Visits: 93.2K
Can you tell if the cylinder is rusty? If that is the problem you could turn the block upside down and fill the cylinder with a weak phosphoric acid ( like COCA COLA ) and give it time and some occasional heat. Pete
Visits: 97
Pete, It doesn't look rusty but it sat outside, without heads, for many months. I'll try the Coke.
thanks
Steve
Visits: 22.0K
If all else fails or you're in a hurry you can cut out the top of the piston with a hole saw, then carefully collapse it enough to get it out.
Visits: 93.2K
Steve. Another thought to free the piston. After soaking a couple of days put the cap on the rod and use a wooden rod to try to twist the piston side to side and free up the rings. Pete
Visits: 190.0K
tight piston 312,just had same isue 292,drilled several holes around the piston,both sides of the wrist pin. 1/2 in holes. then gave it a spach withe hard wood block and a 5lb hamer,piston broke up enough to come loose,tho the water damage made 1 sleev inst necesarey. cliff
Last Active: 8 Months Ago
Visits: 14.6K
Flip the engine with the crank side up and try filling the bottom of the piston with dry ice pieces and let it sit for a while. The piston might shrink enough to pound out.
~DJ~ AKA "Bleach" 1956 Ford Fairlane Town Sedan 30K original miles
Visits: 20.9K
The boys over in the marine business, recommend a mixture of acetone and auto trans fluid, mixed half and half. Only drawback they say is it's a volatile mixture so take care.
Visits: 1.7K
since its at the top drive it down first.just enough to break it free.if you hit it hard enough it will go down.use a mall not a hammer.
Visits: 1.4K
I have had good luck with heat, the penetrant of your choice and a piece of fence post about 2' long that is close to bore size.After a few days of heat and penetrant put the piece of fence post on top of the piston and hit it with a sledge hammer.If you are at .TDC you will need someone to hold the piece of fence post.Once it moves at all you have it,just keep moving it a little at a time.
