Hi Flow water pump
Posted By Buzz 11 Years Ago
Be sure that the high flow water pump you are looking at is not specific for a 1955-1957 Thunderbird.  The T-Birds have a 1” spacer behind the water pump and the high flow water pumps sold for those have modified impellers that will not work on the non-Thunderbird 1” spacer equipped engines.  As Charlie mentions, the standard water pump works for most Y applications.
The stock pump works great for most applications.
Buzz
Question Posted 11 Years Ago
Supercharged (143 reputation)Supercharged (143 reputation)Supercharged (143 reputation)Supercharged (143 reputation)Supercharged (143 reputation)Supercharged (143 reputation)Supercharged (143 reputation)Supercharged (143 reputation)Supercharged (143 reputation)
Last Active: 4 days ago
Posts: 68, Visits: 131.3K
anyone have any recommendations on a water pump for my 56 Crown Vic (312)? I've found a "hi-flow" for $169.00 is it worth the extra $$$ or should i replace with a stock pump
Woodland Hills,Ca
