Visits: 14.3K
This may be a silly question but where is a good source for flywheel and pressure plate bolts? I checked at a local parts store and you could see there eyes glaze over after the words 56 Ford came out. I have looked at Macs and Carpenters but no luck yet.
Durham Missouri
Last Active: 4 hours ago
Posts: 7.4K,
Visits: 205.8K
If you have someone close to you that stocks ARP, then p/n 240-2801 will get you close for the flywheel bolts and p/n 150-2201 will get you a set of pressure plate bolts. Jegs, Summit or some of those other mail order houses can also fix you up.
Visits: 14.3K
Thank you kind sir.
Durham Missouri
