For sale Pair ECZ-G heads with rockers, total rebuild, never installed
Posted By 1957LAPD 11 Years Ago
For sale Pair ECZ-G heads with rockers, total rebuild, never installed...
1957LAPD
Hitting on all eight cylinders (6 reputation)Hitting on all eight cylinders (6 reputation)Hitting on all eight cylinders (6 reputation)Hitting on all eight cylinders (6 reputation)Hitting on all eight cylinders (6 reputation)Hitting on all eight cylinders (6 reputation)Hitting on all eight cylinders (6 reputation)Hitting on all eight cylinders (6 reputation)Hitting on all eight cylinders (6 reputation)
Posts: 2, Visits: 9
This set of heads has new seats and guides, valves refaced and lapped (all genuine Ford), plus all new rocker arms. Shipping weight about 120#'s total. cost to be determined by zip code, in the lower 48 states only.
$650.00
Robert ; (406) 830-5733
Some technical info is needed by Forum members who might be interested in what you are offering...
1) What are the casting letters or numbers on one side of the ribs on each rocherarm?  ECG 6564 or 5751066?  Are they ALL the same I.D.?
2) Are the casting letters found adjacent to the cylinder head to intake manifold flanges large letters or small casting letters ECZ-G
3) IF your heads have the large casting letter ECZ-Gs, are they the early '57 un-posted units or the later '57 FoMoCo and '58 Merc 'posted' heads?
IF you need help in determining if your heads are 'posted' or not, see the following web page   http://yblockguy.com/techtips/postedheads.html
Hope this helps.  Thanks for listing your parts here, Robert.    Smile
Y block Billy
Posts: 1.6K, Visits: 5.2K
It appears from looking at the rockers that there are both some high ratio and some low ratio. I normally tell this by looking at the oil channel that feeds the ball of the rocker, the ones that are about 1/4" long are the low ratio and the ones that are about 1/8" long are the high ratio. Just looking at the shafts you can tell the ones with the shorter oil channel have a shorter distance from shaft to ball and end of the rocker.
55 Vicky & customline
GooD info, Billy.  My age is showing... I think I knew that once myself.  Hehe
THANKS for coming in on this.  Some of our newer Forum members may appreciate the info.
Regards,
Posts: 287, Visits: 1.7K
these would be posted heads since i see no date code..the one i can see at any rate.
1957LAPD
Posts: 2, Visits: 9
Thank for the very observant replies... They are appreciated.  FYI, the heads have been sold.
Cheers,
Robert Stentz
flathead jack
Hitting on all eight cylinders (16 reputation)Hitting on all eight cylinders (16 reputation)Hitting on all eight cylinders (16 reputation)Hitting on all eight cylinders (16 reputation)Hitting on all eight cylinders (16 reputation)Hitting on all eight cylinders (16 reputation)Hitting on all eight cylinders (16 reputation)Hitting on all eight cylinders (16 reputation)Hitting on all eight cylinders (16 reputation)
Posts: 7, Visits: 188
are the ecz-g heads still avaialble
Last Active: 5 days ago
flathead jack (2/9/2018)
Are the ecz-g heads still available?
The post before yours says the heads were sold.  You might try putting a new WTB ad in the classifieds for the heads you need.
