Visits: 38.5K
John, Yes I did. Thanks for the information. It will be a while before I can seriously consider it though. Glad to hear the Hurricane is ready to go again. Can't wait to see it run! Always a pleasure. Chuck in NH
mr4speedford
Visits: 923
Congrats on the engine, one question: Were you able to get the pistons without the dome or did you modify them yourself for your blower application?
1959 and 1960 f-100sAkron OH
Canadian Hot Rodder
Visits: 1.3K
You know John, if you are bored and have nothing to do now that you are retired,  you can always build a nice blower motor for my 56! Consider it a nice token of friendship for your neighbor up north!  Rob
Last Active: 5 hours ago
Visits: 323.2K
Mr4speed: I used 6.300 long Eagle rods for large journal sbc. Had the pistons honed out for the chev pins. Narrowed the big ends of the rods to Y size. Had the crank ground to chev size at stock Y stroke. Decked the block just enough to get it square and equal on both banks. Pre-assembled the short block without rings, and used a dial indicator on the flat portion of the pistons to find that they came out of the block .034. So I machined off the dome plus another .034 to get 0 deck. There are two very small eyebrows left of the original valve clearance notches. Glad I didn't have the crank stroked, the pistons may have been too thin on top with 6.300 rods. John in Selma, IN
mr4speedford
Visits: 923
Thanks for the info.
JPotter57
Visits: 1.2K
John, On using SBC type rods, when you narrow the big ends, what is the difference in sizes, and is it enough to foul up rod bearings? Or can standard, non-modified bearings be used? I am still calculating and working long rod combos in my research. I saw those 331 Ford (mod motor) rods that are something like 6.6 or so, but that's just a little much, unless you do custom pistons. I got a form from Wiseco today, and for $800 or so, I can have a set custom built to my specs (ring lands lowered, thick crown for gobs o` boost, etc). Before I can do any of that though, I have to find a good rod though.....
James Potter `57 Fords International
`57 Custom Tudor
`57 Fords International National Director
Pass Christian, MS (near Gulfport/Biloxi)
Visits: 323.2K
James: The sbc rods are .943, the Y .871, so I had to take off .042. The chev big ends are offset, so I took all the material off the "wide" side of the rod. I made a fixture so I could cut a chamfer on the bearings to clear the radius on the crank. The crank guy said they make a chev bearing that is narrower, just for that purpose. I used the standard bearings and chamfered them. I would go with the Wiseco if I were you. Cost isn't that much more, and you will have a thicker piston top, I'm sure you are going to use more boost than I do. John in Selma, IN
Moz
Visits: 3.7K
congratulations john great news to hear the hurricane is alive & well & wanting to eat scrubs for breakfast wish i could see it in person. moz.
 moz. geelong victoria australia. graduate 1980, bus, truck, car, hot rod, boat, submarine, hovercraft, hydrafoil, firetruck, mobile home, jet, helicopter, cruise ship, motorcycle, bicycle, santa's sleigh, clock, alloy bullbar, alloy fuel tank, lens, dr who's tardis, matter - anti matter warp drive buffer & y-block lover
Y block Billy
Posts: 1.6K,
Visits: 5.2K
You Can Moz, Just jump on the band wagon with Lon & his mates, He may have to rent a bus from Cal to Columbus though.
Moz
Visits: 3.7K
hey billy nothing i would love more than to come to columbus but it's my busiest time of the year from now untill about mid october it's 12-16 hour days and sometimes as this week was 7 days oyh well maybe when i retire !
