Visits: 2.0K
I will be using John's Y-280-I-11 cams. I have all the parts from John to start the engine build. So the engine will be heading off the machine shop next week. I won't be able to finish the engine until I receive the remainder of my order (aluminum heads, timing cover, flywheel, and clutch). If I can figure out how to post pictures on this forum...I will post progress during the build of my .060 over 292 EFI engine.
Visits: 7.8K
got the new cam and reworked heads installed, got to get it off the stand and into my cradle to finish it up
Posts: 3.3K,
Visits: 238.8K
That's one of the Cams that Mummert came up with about a year or two back. It was featured in a build, if I recall, for use with a C-4 transmission on the street. The test is published & it tested out (if I recall, without looking it up) in a moderate stroker setup at a very impressive, 393 HP & 420 Lb Ft.! .. The only minor glitch with it (for someone dreaming like me) is that it isn't recomended for use with a Fordomatic, due to the Fordo's converter..
