Distributor
Posted By 55Birdman 17 Years Ago
55Birdman
Posted 17 Years Ago
Posts: 1.0K, Visits: 4.5K
Need 57or later distributor or msd,or unilite or something better than the stock 55 I have in my 292. eadgpdhome@msn.com thanks
55Birdman Smile  Hickory NC
Posted 17 Years Ago
Posts: 3.7K, Visits: 32.5K
YOU MIGHT TRY AUTOZONE.They list the distributors as an exchange unit online.Whether they can actually supply them is another question.What will you do with your Petronix unit.They are different for the later distributors?
Eddie Paskey
Posted 17 Years Ago
Supercharged (294 reputation)Supercharged (294 reputation)Supercharged (294 reputation)Supercharged (294 reputation)Supercharged (294 reputation)Supercharged (294 reputation)Supercharged (294 reputation)Supercharged (294 reputation)Supercharged (294 reputation)
Posts: 294, Visits: 6.1K
Hey 55;  I got a late distributor from Autozone, only about $60.00 including core charge. I did not have the old one because of it being a 55 Dist.  Put in a petronics with their flamethrower coil, and has worked great.  Hope this helps  God Bless!
Eddie
Lake Forest, Ca. 92630
Eddie
55Birdman
Posted 17 Years Ago
When I installed the petronix unit in my 55 they didnt make a 6v unit. My bird was switched to 12v so I bought a 12 v unit and installed it in my distributor. Autozone lists the same part number for 55 56 and 57 distributor. Is it gonna work?
PWH42
Posted 17 Years Ago
Posts: 854, Visits: 6.0K
I believe the shaft size is different between the 57 and 56 distributors,so the Pertronix unit is not interchangable.If your's is in 55/56 dist.,it won't work in a 57or newer dist.
Paul,
Boonville,MO
55Birdman
Posted 17 Years Ago
The petronix I installed was for a 57. I had to do a little mod on it to get it to install. been working fine for about 8 years.
Posted 17 Years Ago
Posts: 3.7K, Visits: 322.2K
Birdman:
If this distributor is for a Bird, the ones mentioned above will not have the tach drive.  '57 T-Birds were the only ones with factory tach drive and mechanical advance.
John in Selma, IN
55Birdman
Posted 17 Years Ago
mine has a tach drive. How do I know what year it is? Any ID or anything. maybe it is a 57
GREENBIRD56
Posted 17 Years Ago
Posts: 1.7K, Visits: 102.7K
If your distributor has tach drive - and doesn't have a "dual advance" vacuum pot hanging on there ------- meaning the one with the two piggyback cans and two ports for the old teapot carb -----it would likely be from a 57. I believe a 55 or 56 tach drive would have the double can.
I think the 57's had a "ball bearing" point plate pivot too.
The "single advance" style vacuum pot (57 and later) will have a hex nut on the nose (where the vacuum port enters). If you dismantle this nut- there are shims under there to preload the spring and change the rate of vacuum advance per inch of Hg. If you put in a lot of initial advance (12°-14°) at idle - and don't limit the total centrifugal - it is possible to mechanically "over advance" the spark at elevated revs. Even if you limit it (36°-38° would be a good maximum) the vacuum pot might add enough at cruise to cause a knock. So ----- adding shims to the vacuum pot is a way to cut back on how much advance it can add on to the total at elevated vacuum.
55Birdman
Posted 17 Years Ago
Thanks for the info. I looked on mummerts site and found that the vacuum advance arm is straight on the 57. but the serial number isnt the same as listed. Mine is model FF17E. which is in no way what mummert has. But I do have shims and all the other visuals he describes as 57. so I will go with the assumption that mine is 57. Thanks for the info .
