Y block oil filter question
Posted By timmy4 17 Years Ago
timmy4
Smile Posted 17 Years Ago
Supercharged (362 reputation)Supercharged (362 reputation)Supercharged (362 reputation)Supercharged (362 reputation)Supercharged (362 reputation)Supercharged (362 reputation)Supercharged (362 reputation)Supercharged (362 reputation)Supercharged (362 reputation)
Posts: 280, Visits: 523
  1. I am rebuilding a y block engine and I am replacing the canister filter with a new one and I want to make sure I am doing it right. A rubber washer goes
    on the bolt first and after you insert it in the filter housing you put another rubber washer on then the double spring then the filter cartridge and finally
    the housing gasket. Thank you.
Posted 17 Years Ago
Last Active: 47 minutes ago
Posts: 3.7K, Visits: 323.2K
Timmy:
The gasket under the head of the bolt should be a rigid fibre gasket, or you won't be able to tighten the can enough to keep it from leaking where it seals against the block.  So the sequence would be: fibre washer, can, spring, rubber washer, filter cartridge, rubber washer.  There is also a rubber gasket where the can seats against the block.
John in Selma, IN
timmy4
SmileThanks John for the help. I am rebuilding a engine for my 1955 ford custom line
Posted 17 Years Ago
Timmy:
You're welcome.  Incidentally, most of us Y guys use the adaptor kit and convert to spin on oil filters.  But, if you want your '55 to be "correct", you have to use the cannister.
John
