Visits: 340.0K
Offenhauser manifold. Satin clear powder coated. Exhaust passage high temp powder coated. *Charlie Price Vintage Speed Rochester 2GC carbs, marble finish clear chromate, cast iron bases mixture adjustment on cent carb only. Center carb converted to an electric choke.*Custom 3 hole to 4 hole carb adapters. *Phenolic insulators under carbs. All new hardware. *Custom progressive linkage on right side behind and under the chrome fuel block and chrome fuel lines. Custom throttle linkage arm to stock manifold mounted linkage.*Steel vacuum line from the center carb to the distributor for post 57 dist. 3 chrome air bonnets old style no louvers. Fuel line from fuel block to T-Bird style filter included.
