Extra water holes in C2AE blocks?
Posted By 46yblock 18 Years Ago
Doug T
Posted 17 Years Ago
Posts: 563, Visits: 2.6K
Interesting Thread.  I have always drilled the "steam holes"  although as was said above that is probably a misnomer.  As long as the water temp in the area does not exceed the boiling point of the coolant mix at the rad cap pressure, there will not be steam there or anywhere else.  But I remember reading about some Smokey Unick research  on Y's when he ran them in '57.  He found significant temp differences in various locations of the water jackets and there could be local boiling which would not show up in the temp gauge.  It may be that Ford found this also with research and specified the holes as a fix.  Because Ford would be using clean blocks and coolant the holes would not be crudded up.
My guess is that the boiling and overheating takes place primarly when the engine is shut down hot and water circulation is only thermo syphon.  Then the holes would pass water to the area between the ex valves where the heat would build up quickly, cooling that area.
BTW Ted mentions another interesting Y design feature that has a little bit of unintended concequences.  Since the the temp probe is located in the back of the head near where a large part of the water flow from the rad comes up from the block,  the water exiting the head is likely to be some what hotter.
I don't know if it helped or not but I have a magazine picture of Doane Spenser's T bird motor that has beautiful water manifolds the take water from the back and front of the heads.
Doug T
Rono
Posted 17 Years Ago
Posts: 1.3K, Visits: 80.0K
I am building a C2AE block with 471 heads. I believe both the heads and block have the factory steam holes. I have never used the Best head gaskets (only Fel-Pro) and wondered if they have the steam holes?
Rono.
DANIEL TINDER
Posted 17 Years Ago
Posts: 1.8K, Visits: 154.6K
Best gaskets DO have the holes.
6 VOLTS/POS. GRD. NW INDIANA
speedpro56
Posted 17 Years Ago
Posts: 1.3K, Visits: 9.2K
The only time I ever found crud in a steam hole would be when the block was drilled and the head was not and the coolent couldn't pass thru. When the holes were in the block and head I have not yet found crud buildup that bad and this may well be the engines always had antifreeze changed yearly ?????
-Gary Burnette-
aussiebill
Posted 17 Years Ago
Posts: 1.8K, Visits: 11.4K
Rono (12/12/2009)
Rono.
Rono, yes the Best gaskets do have the steam holes in them. Must say i,ve allways drilled my engines and never had any problems with the steam holes. best regards bill.
 Down Under, Australia
46yblock
Posted 17 Years Ago
Posts: 1.2K, Visits: 7.8K
speedpro56 (12/12/2009)
I suspect the abscence of changing antifreeze on this '64 is the reason for the plug.  The block is like new except for a mess within the coolant passages.  It looks like the antifreeze was never changed after rebuild, except for when the radiator was replaced.  Even then the owner probably only drained the radiator.  Rebuild was done in 1994, and engine had 11,000 miles over the next 10 years.  Then it sat idle for 4 or 5 years.
