Electrolysis question
Posted By ian57tbird 10 Years Ago
ian57tbird
Posted 10 Years Ago
Posts: 489, Visits: 20.9K
I was not sure and wondering if there would be any problems with electrolysis if I used a plated steel heater hose connection into an aluminum intake manifold?
The Master Cylinder
Posted 10 Years Ago
Posts: 974, Visits: 6.2K
Not sure on the electrolysis but I would suggest not using stainless on aluminum unless you use an anti-sieze compound. The stainless will gall the threads in the manifold and not only ruin the threads but make it extremely difficult to remove if need be.
I recall there was a discussion on stainless galling in the past, but of course I can't find it...w00t
stuey
Posted 10 Years Ago
Supercharged (840 reputation)Supercharged (840 reputation)Supercharged (840 reputation)Supercharged (840 reputation)Supercharged (840 reputation)Supercharged (840 reputation)Supercharged (840 reputation)Supercharged (840 reputation)Supercharged (840 reputation)
Posts: 438, Visits: 3.8K
any one use this stuff? boat guys maybe. http://www.tefgel.com/contain.php?param=tefgel_infor
I use ARP anti seize or, in your situation Arp pipe seal which sounds similar to the Tef-gel
stu
2721955meteor
Posted 10 Years Ago
Last Active: 6 Months Ago
Posts: 927, Visits: 190.0K
with aluminum manifolds and heads always use anty freeze, have witnesed many eaten intakes  frome the southern us wher no atyfreez is  needed.use the proper stuff for longer life,change every 2 years. just my opinion.
