Auto Shop Teacher Dan
Visits: 10
I have come into possession of a Mummert manfiold. Looking on his web site it would appear to be a low rise model. It is in perfect shape and has a cast iron thermostat housing and the rubber hose and the two bolt adapter for the thermostat bypass. It came off a Bonneville race car. Does anyone have an idea of what they are worth now days? Thanks for any help you can give me. Dan
Last Active: 8 hours ago
Posts: 7.4K,
Visits: 205.7K
Is it the Mummert intake or is it the Blue Thunder? The Mummert intake will have ‘Mummert’ cast on it in front of the carburetor flange. The Mummert intake is also cast without the heat crossover in the middle. The BlueThunder intake will have the heat crossover and will also have the Ford part number cast on the intake behind the carburetor flange.
Visits: 10
It says "Mummert" on the manifold and I looked on his web site and he has two manifolds. I don't have the measurements but looking at the pictures it appears to be the lower of the two.
Dan
Posts: 3.3K,
Visits: 238.8K
Mummert's new price last fall (2013) was $419 U.S. either model. Aluminum holdowns were extra, all + shipping.
jimcar-9
Visits: 894
what do you want for it?
Best regards Jimmy Carlsson, Fagersta (Sweden) Ford F100 1956, 272 , 3 manual with OD Follow my restoration on http://dinnerhillspeedshop.blogspot.se/
Visits: 10
Jimmy, After much discussion I have decided to ask $375.00 for it. Even though it is used it is in excellent shape with all threaded holes in perfect shape and all machined surfaces flat and smooth. It worked like a charm on the 292 at Bonneville and should work great for the next owner. The proceeds will go to the project I am working on which is the re-creation of my first car. Dan
Visits: 10
I should mention that I will throw in the 2" plastic carb spacer with studs. I will take some pictures on Wednesday and post them here for all to see.
Visits: 442.6K
I moved this to the classifieds.
CK
Visits: 1.1K
Would you take $320 for it? And are you ok with shipping?
jimcar-9
Visits: 894
I'll think I pass, I dont need the spacer and I need the straight termostat Truck housing. I'll buy them of mummert. Thanks anyway
