292 Dies at Acceleration
Posted By '59Edsel 12 Years Ago
Daniel Jessup
Posts: 2.0K, Visits: 131.2K
'59Edsel (6/25/2014)
Took her out again today, still doing the same thing. If I really punch it she'll move past that dry spot and be fine after that. Seem to accelerate well while at speed. If I'm in reverse and going up an incline, the engine will do the same thing, scary thing there is after it moves past the bogging point, the engine will really let loose and then my driveshaft just bangs the differential into movement. I hear that loud clang of a driveshaft typical when you change from forward to reverse…almost feel like she'll burn out. Gotta be careful though, don't want to shatter my diff.
This kind of concerns me and makes me wonder if you don't have transmission problems - even if your engine is stuttering, coughing, missing, etc, your torque converter shouldn't be letting your driveshaft bang/clang your differential like you are driving a manual transmission car. Your earlier post about the transmission puking ATF while it is COLD and you are revving the engine sounds like the trouble might be there. Your engine/driveline only act that way (under 10 mph under acceleration right?) when you are under load? And it sounds like your engine is responding correctly when not under load and your revving the throttle in neutral or park...
What is the history of the transmission?
Daniel Jessup
Red Lion, Pennsylvania
'59Edsel
Supercharged (422 reputation)Supercharged (422 reputation)Supercharged (422 reputation)Supercharged (422 reputation)Supercharged (422 reputation)Supercharged (422 reputation)Supercharged (422 reputation)Supercharged (422 reputation)Supercharged (422 reputation)
Posts: 163, Visits: 3.5K
Here is a video with the vacuum advance disconnected:
http://oi43.tinypic.com/vyxn49.jpg
'59Edsel
Ted (7/11/2014)
Did you check the ignition timing curve with the vacuum advance disconnected?  It should be smooth and without any erratic movements as you bring the rpms up and down.  The timing should also return back to the same initial timing setting each time at idle also.
I will do this and try to capture it on video.
Posts: 7.6K, Visits: 206.1K
'59Edsel
Vacuum advance I bought didn't fit, but it appears the old one is working ok. So it looks like we can rule out accelerator pump and timing. What else could it be?
'59Edsel
I haven't checked the vacuum advance yet, but as a precaution I went ahead and ordered up a new one. The one on there is original and I can't imagine the rubber is any good..
'59Edsel
I will do this! Thanks
If this is related to an ignition timing problem, then by using a timing light and observing the timing curve at the damper while running the rpms up and down may indicate a distributor that has erratic or sticking curve attributes.  I would check the timing curve with the vacuum advance both unplugged and hooked up and observe each.
'59Edsel
If
'59Edsel
Okay, and update for today...
I visually tested the accelerator pump and it is shooting a nice stream into the carburetor on each side. So that seems ok.
I took out the check ball on the top of the accelerator pump and it's beautiful, not a pit on it.
…Still need to see the timing.
[And I stopped all testing when one of my other problems reared its ugly head after a long hiatus. My tranny overflowed out of the fill tube. It's an original 2 speed Mile-O-Matic. I was revving the engine (While cold) and it overflowed from the fill tube. Hasn't done this for a while. When hot, the dipstick shows the perfect level. Not sure why its overflowing. And yes its the correct dipstick. I'll post this on my old thread about it…]
