Clutch and Brake Pedal Pad installation
Posted By Daniel Jessup 11 Years Ago
Daniel Jessup
Question Posted 11 Years Ago
Posts: 2.0K, Visits: 130.7K
I am working on the restoration and installation of the clutch and brake pedals in the 55 Club Sedan to install the 3 speed with overdrive. For all of you that have put on the new rubber covers over your metal pedal, how do you install the pad so it has a tight fit? Do I need glue or some type of bonding agent? The rubber from Dennis Carpenter looks like it will not slip over the pedal unless I heat it up quite a bit. Any ideas?
Daniel Jessup
Lancaster, California
lyonroad
Posts: 703, Visits: 3.1K
I did mine about a year and a half ago and as far as I can remember I just forced it over the metal part.  Did not use any glue.  Mine came from Jamco Suspension. My problem was I couldn't decide which way to orient the pattern on the pad.
In retrospect Daniel, I may have heated it up in boiling water and used some sort of lubricant like soap.
Mark
1956 Mercury M100
1955 Ford Fairlane Club Sedan
Delta, British Columbia
slick56
Posts: 460, Visits: 4.5K
I used methylated spirits, lubricates it enough to put on, then evaporates.
South Australia
Daniel Jessup
Thanks fellas, got them done this morning... it was easier than it looked and they are on solid.
man that new rubber smells HIGH!
Daniel Jessup
