chiggerfarmer
Visits: 3.8K
I used a water valve like that one on my 54 and it worked. Just make sure it is a "vacuum opens" and not the other way. There are both kinds. You will not get as much control of the temperature with these as with the original water valves. Some way the originals were made to allow adjusting the open position to relate to the dash control lever. All you will get from these newer ones is either on or off. No in between settings. Otherwise works great.
Tom from the chiggerfarm located in the beautiful Heart of Central Texas
When you cannot dazzle others with your brilliance, baffle them with bullcorn!
ian57tbird
Visits: 21.7K
The second link looks like it could be the original part in the heater plenum. It's an early form of climate control that uses a bimetal strip to vary the vacuum to the valve on the manifold. The vacuum opens the valve on the manifold, to test just connect it to a vacuum source when the car has warmed up and running then try the heater fan. If it opens you'll start to get hot air, fingers crossed.
slick56
Visits: 4.5K
I was considering using one of these inline
South Australia
ian57tbird
Visits: 21.7K
Yes, I can't see any reason why you can't take it straight off the manifold. there is very little vacuum-air flow through the heater control as long as there are no leaks.
As long as the rubber diaphragm in the controller in heater plenum is in tact, then that part is serviceable, as long as your good with nutting out finicky things. I suspect the diaphragm can't be bought now.
Posts: 1.9K,
Visits: 194.9K
If you don't have a vacuum leak, you'll be fine. But there's been a lot of trouble with the vacuum water valve, either failing or leaking. One of the T-bird suppliers, who's name unfortunately escapes me, told me they had a new supplier with better results. I think they were in Nevada, but not sure. For years the T-bird suppliers sold a replacement, an inline valve in the heater hose, two clamps, and a cable that ran from the heater control lever to the valve, thru the hole the vacuum hose used in the firewall. It was a bit overpriced compared to making your own, if you buy a cable, and "wrap" the eyelets on the end. I've had mixed results with those valves not really shutting off. I've got one inline, and the intake manifold fitting (or original vacuum valve) replaced with a 90 degree one with a shut off built in. In the winter, I use the cable, but in the summer I shut it off at the manifold to stop the "leaking heat" from overwhelming the a/c. I would imagine you could do something similar on pass car. Simple, cheap, and works. Obviously, it doesn't look stock. http://www.macsautoparts.com/ford_mercury_early/hot-water-heater-shut-off-valve-threads-into-cylinder-head-ford.html#http://www.americanclassic.com/Google_Base_HTML_Pages/HAC-139-1942.htmThese are typical.
Visits: 497.8K
Poor wiper action may be the flapper inside the unit. Over time they dry out (supposedly leather). One solution is to find the vacuum line in the engine compartment that goes to the wipers. Disconnect it in the engine compartment and insert it a can of ordinary dot 3 brake fluid. Manually work the wipers so the fluid is sucked into the wiper motor ( better off if you have two guys do this, one at each wiper blade). Let it sit overnight. The try it the next day -wet the windshield first.
Another method of doing the same thing is to get a piece of hose and attach it to the vent at the bottom of the wiper motor. Stick the other end in the fluid and start the engine so the fluid is sucked up into the wiper motor. Again. let it set overnight and then try it.
In both cases, put something on the carpet under the wiper motor to catch any drips. You may get a lot of smoke when you restart the engine as some of the brake fluid may get sucked in it.
Meandean (5/9/2014) I have a '55 Fairlane. Vacuum wipers go 1/4 of the way up the window and stop. I noticed last fall when I was about to put it away for the winter that the heater alternately worked (blew warm air) and then didn't (blew cold air). There was also a flapping sound occasionally. Any idea where my troubles might be? I don't want to have to crawl under there and remove the wiper motor if it's not the problem for sure (Rain-X is my savior). I wouldn't be opposed to a off only-on heater only solution.
slick56
Visits: 4.5K
Hoosier Hurricane (5/9/2014) You didn't say what car you're working on, I assume it is a '56 as in your pic. The vacuum to the heater tees into the vacuum hose to the wiper motor, under the dash. The hose connects to the vacuum control valve inside the heater box, from that valve it goes to the water valve on the intake manifold.
Yes, 56.
Mine has been converted to electric wipers, will it be ok to pull vacuum from rear of manifold?
(I have also used this port for brake booster).
I've read elsewhere on here that this can lean out the rear cylinders if i have a vacuum leak.
South Australia
Meandean
Visits: 137.7K
Last Active: 4 hours ago
Visits: 323.2K
lyonroad
Visits: 3.1K
Jim Rowe (5/9/2014)
Al,
I made mine simple, I used a manual shutoff on the hot water from the manifold. Works for me. Open in the winter and closed in the summer.
Jim
I'm thinking of doing that too. The vacuum shutoffs seem quite expensive, even the offshore versions.
Mark
