Posts: 3.6K,
Visits: 497.7K
I haven't seen any thing to click on for PM's. Probably right in front of my nose but?
Posts: 2.0K,
Visits: 130.9K
Look in the upper right hand corner, there is a "button" with an envelope symbol. Click it and see what happens.... If you have the symbol of course.
Visits: 6.0K
I don't have any of the symbols at the top.This is the ffirst time I've posted since the change,so I'm wondering if this will work.
Paul, Boonville,MO
Visits: 894
PWH42 (4/2/2014)
I don't have any of the symbols at the top.This is the ffirst time I've posted since the change,so I'm wondering if this will work.Just put the cursor over the "picture" of the memebr you want to pm and then you can send a pm, or go to your profile under messages...
Best regards Jimmy Carlsson, Fagersta (Sweden) Ford F100 1956, 272 , 3 manual with OD Follow my restoration on http://dinnerhillspeedshop.blogspot.se/
Posts: 2.0K,
Visits: 130.9K
you can also click the gear in the upper right hand corner and then click "inbox" from the drop down list to go to your PM folders
Posts: 3.6K,
Visits: 497.7K
Thanks - I see it. I guess nothing shows up until you get a PM
