Visits: 1.1K
Same as in 1.54 or 1.43? What about FE rockers? Is the shaft and valve tip in similar geometries?
Visits: 5.2K
My set of New Rocker Arms [just 1.54 rockers No adjuster or any other stuff]] came end of last week. Look nice. .Steve McD
Mars , Pennsylvania
Visits: 5.2K
I left out where from.. They came from John Mummert
Mars , Pennsylvania
Posts: 7.5K,
Visits: 205.8K
CK (5/11/2014)
Same as in 1.54 or 1.43? What about FE rockers? Is the shaft and valve tip in similar geometries? The FE rockers fit a larger diameter shaft. The rocker ratio for adjustable FE units is also 1.76:1. I suspect the length is also different from the Y rockers but because of the shaft diameter and mounting irregularities, I’ve made no attempts to use FE rockers on a Y . Ted.
Visits: 946
if falcons have the same arms they would be pretty easy to find! i wonder if anyone has one laying around that they can check?
