Where to buy NEW 1.54 ROCKER ARMS
http://forums.y-blocksforever.com/Topic103195.aspx
By aussiebill - 11 Years Ago
Guys, where can i buy new 1.54 rocker arms, am only after the rockers and not assy,s. Thank you all. Regards bill.
By MoonShadow - 11 Years Ago
Try John Mummert at: http://www.ford-y-block.com/valvetrain.htm I think he had some new ones. Chuck
MoonShadow (3/26/2014)
Chuck, john had advertised them with shafts etc as i understand it, and was only after the arms, thanks. , i will pm him. regards bill.
John does sell them individually without shafts, I recently got some.
Are the rockers mixed on the shafts or is it a right and left set with different rockers? Some folks have changed half the rockers on the same banks to effect the cam. Not sure what was done but either the intake or exhaust rockers were switched out. Chuck
By lyonroad - 11 Years Ago
MoonShadow (3/27/2014)
I recall Ted saying something about this a while back.  I did a quick search but could not find it.
By The Horvaths - 11 Years Ago
Games like high ratio intake and low ratio exhaust can help to trade some loss of top-end HP for a gain in low-end torque.
Off the shelf, John's high ratio ass'y came all high ratio. If you wanted custom, I imagine he'd do that too.
Y block Billy (3/27/2014)
I had pm,d him twice on here but no reply, not sure if its working! in the meanwhile customer settled for used set.
By Lou - 11 Years Ago
The Falcon 144 & 170 six cylinder engines used the same rockers as the y block.
By PF Arcand - 11 Years Ago
Interesting, if that's true. I wonder if any Ford dealers might still have those parts?  Otherwise it would require finding two salvage engines to get a full 8 cyl set. And what ratio are they?
By CK - 11 Years Ago
Same as in 1.54 or 1.43?
What about FE rockers?
Is the shaft and valve tip in similar geometries?
By thundercat - 11 Years Ago
  My set of New Rocker Arms [just 1.54 rockers  No adjuster   or any other stuff]]    came end of last week.  Look nice.  .Steve McD
I left out where from.. They came from John Mummert
By Ted - 11 Years Ago
CK (5/11/2014)
The FE rockers fit a larger diameter shaft.  The rocker ratio for adjustable FE units is also 1.76:1.  I suspect the length is also different from the Y rockers but because of the shaft diameter and mounting irregularities, I’ve made no attempts to use FE rockers on a Y .  Ted.
By brainfreeze - 11 Years Ago
if falcons have the same arms they would be pretty easy to find! i wonder if anyone has one laying around that they can check?
