Cams, Valves, Lifters for 292 Interceptor
Posted By raleypc 12 Years Ago
raleypc
Hitting on all eight cylinders (11 reputation)Hitting on all eight cylinders (11 reputation)Hitting on all eight cylinders (11 reputation)Hitting on all eight cylinders (11 reputation)Hitting on all eight cylinders (11 reputation)Hitting on all eight cylinders (11 reputation)Hitting on all eight cylinders (11 reputation)Hitting on all eight cylinders (11 reputation)Hitting on all eight cylinders (11 reputation)
Posts: 3, Visits: 41
I am rebuilding my 1958 185HP Dearborn Interceptor (292 Y-Block w/two Carter YH carbs) in my 1958 Century Resorter speedboat and I have a few questions. The original block and heads (EBZ-G...sob) have damage due to salt water so I am rebuilding what I think is a 56/57 automotive 292 (EBZ-C heads)
1. The original cam had wiped one lobe. I have a used original in reasonable condition from the 56/57 motor. Should I use this, buy a stock replacement for $70 -$80 from Dennis Carpenter, or invest in aftermarket mid range cam (Erwin 210/210 for example) at around $215. The rpm range is currently 700 to about 4200 WFO when in perfect tune. It would be nice to get a few more ponies around 4000 to 4500 that could equate to few more MPH, however, smooth idle is important.
2. I understand that earlier 351W valves can be used to some benefit in small valve heads. The stock intakes are 1.78 in the EBZ-C heads and the 351 valves are 1.84. Any benefit in my operating range or should I stick to the stock sizes? The 351W spec a tad longer...is that a problem?
3. I plan to replace the lifters. Are the ones on ebay at $100 a set (likely Asian origin to OEM specs...so they say)to be avoided? The cheapest I found for a USA made set is $175.
Thanks!
Paul R.
