TIMECOVER SEAL
Posted By aussiebill 12 Years Ago
aussiebill
Posts: 1.8K, Visits: 11.4K
I,ve allways wondered why our y blocks never had the timeing case seal enter from the front like majority of engines, cant see why it was done as it would only needed to have been machined from the front, leaving the lip on inside area, certainly would save a lot of extra work and gaskts if it was so. Just my long time thought.
yyy
 Down Under, Australia
slick56
Last Active: 3 Weeks Ago
Posts: 463, Visits: 4.5K
I imagine the designer was the same bloke who designated the second journal/piston as no.1, and aligned the crank/cam relationship 12 chain links apart..
South Australia
Talkwrench
Posts: 898, Visits: 23.2K
Bill I couldn't agree more.. Ohhh the things I said about the guy that designed that idea ! What a complete pain in the ring that job is Angry .. Guess I made it worse as I did it a few years ago and it was about 100 in the shade.. Doze
lyonroad
Posts: 703, Visits: 3.1K
slick56 (2/27/2014)
Maybe he was British; 12 pence in a shilling, 12 inches in a foot, 12 links between timing marks ... makes sense to me!
Mark
1956 Mercury M100
1955 Ford Fairlane Club Sedan
Delta, British Columbia
John Mummert
Posts: 919, Visits: 7.5K
Sometimes I think that the timing marks were made that way because the set was originally used on the 215 6 cylinder where it might be easier to see the marks it that position. Maybe.
http://ford-y-block.com
slick56
Does the alloy REBOP timing cover take the seal from the front or the rear?
Are they still available (Frank)?
South Australia
aussiebill
slick56 (3/2/2014)
Think john sells them.
Posts: 3.7K, Visits: 323.8K
Rebop's seal enters from the rear like the stock ones do.
snowcone
Supercharged (364 reputation)Supercharged (364 reputation)Supercharged (364 reputation)Supercharged (364 reputation)Supercharged (364 reputation)Supercharged (364 reputation)Supercharged (364 reputation)Supercharged (364 reputation)Supercharged (364 reputation)
Posts: 169, Visits: 5.9K
Must have just been the thinking then for the timing case seal.
If you recall the Aussie GM grey Holden motor from 1948 to 1963 had the seal on the inside too.
Gary - 1958 Star Customline and 1940 Ford Deluxe Hotrod
Talkwrench
Mmm I wonder if the Chevy 6 [blue flame] has it on the inside?
