DISTRIBUTOR ASSY ID - 1957 FORD-BIRD 312CI - E-CODE/F-CODE
http://forums.y-blocksforever.com/Topic168655.aspx
By KULTULZ - Last Year
- DIST ASSY - 1957 FORD-BIRD - 312CI E-CODE -
FEH12127-C (B7A 12127-E) - 1957 FORD 8V - PARTS LIST 23
FEJ12127-B (B7S 12127-B)  - 1957 BIRD 8V - PARTS LIST 25
SINGLE POINT SET - B8Q 12171-A
CONDENSER - B7A 12300-C
BREAKER PLATE (SGL PLATE - 1957-1959) - B7A 12151-A
VACUUM ADV DIAPH ASSY - B7A 12370-A
DIST CAM - B7A 12210-A
DIST ASSY - 1957 FORD-BIRD 312CI F-CODE
FEH-12127-E (B7A 12127-D) - 1957 FORD SC - PARTS LIST 27
FEJ-12127-D (B7S 12127-C) - 1957 BIRD SC - PART LIST 29
DUAL POINT SETS - B7A 12171-B / B7A 12171-C
CONDENSER - B7A12300-B
BREAKER PLATE (SGL PLATE - 1957) - B7A 12151-B
VACUUM ADV DIAPH ASSY - B7A 12370-B
DIST CAM - B7A 12210-B
(DIST COMPONENTS PARTS LIST -1949-1959 FORD MPC)
There were no listing(s) for E-CODE DUAL POINT DISTRIBUTORS
 EXAMPLE - FEH-12127-E IS THE DIST IDENTIFICATION NO FOUND ON THE DIST BOWL
                   - B7A 12127-C IS THE ACTUAL FORD P&A SERVICE PART NUMBER
The above information is drawn from the 1949-1959 FORD MPC - FINAL EDITION
It only represents FORD SERVICE PARTS, not necessarily ASSEMBLY PARTS
or any parts which may have been released in HP KITS or SERVICE LETTERS.
By DANIEL TINDER - Last Year
Interesting that the F-code/dual point condenser part # is different from the E-code one.  I found a wide range of electrical values from a grab bag of NOS condensers, all seemingly identical, so the specific value spec. would likely be more relevant than any part # (?). Maybe the dual point outboard mounting is the issue (?).
By Hoosier Hurricane - Last Year
If I remember correctly, the difference in condensers is the length of the lead wire.
I would think the rating is higher as it has to absorb more as a result of the longer dwell time and coil saturation.
My WSM's are buried or otherwise I would find out.
http://forums.y-blocksforever.com/uploads/images/4c02c9af-0fe3-42ba-9083-0635.png
