Front Engine Mount
http://forums.y-blocksforever.com/Topic152412.aspx
By MattsY - 6 Years Ago
Ok, stupid question of the day here. Is the front engine mount a necessary piece on a 1954 Crestline? I got my engine all assembled and completely forgot about that silly mount. It attaches to the face of the block as well as the two, front oil pan bolts that go into the timing cover. That's not really an issue, but the fact that it must go on before the damper and pulley does complicate things a bit. Yes, I'm being lazy and don't want to bother pulling the damper off, but I will if it's a critical piece. Thanks for your time!
By oldcarmark - 6 Years Ago
Many of these were removed over the Years and not replaced. Discontinued after 1956. As long as your side Mounts are in good Shape You should be fine. Others will have their Opinion I am sure.
By PF Arcand - 6 Years Ago
As Mark says, it may not be necessary on a '54 Ford. Actually, Ford apparently referred to it as a "steady rest" I believe. A time that it could be an issue, is if you are removing the Transmission?  Depends on the trans mounts or cross members etc?..
By darrell - 6 Years Ago
its the first thing i get rid of when changing a motor.
By paul2748 - 6 Years Ago
I went in the opposite direction.  When I installed the 312 in my 54, I used the steady rest as I figured better to be safe than sorry.  If your installing a later Y than a 54, the 54 steady rest will not work.  You must uses a 55 or 56 unit.because of damper interference on the 54 steady rest.
I removed my 56 when I added a transmission that needed cooling lines and to add clearance for the fan shroud I added. So far there has been no seen problem.
Thank you all! I will not be putting it back then. The transmission thing sounds logical and thinking about it, it's a pretty good idea, but when it comes time to change the clutch or something again, I'll just have to support the motor like I've always done.
By Lou - 6 Years Ago
Matt, just hope you don't ever have to make a pantic stop.
By Ted - 6 Years Ago
Here’s the link to an older thread on the subject.
http://forums.y-blocksforever.com/FindPost20560.aspx
I will add this.  That piece attached at the front of the engine that is so often confused as a front engine mount on the 1954-1956 cars is a steady rest.  It is more for ride control and driving stability than as a engine support.  Add this to the list of items you got when you purchased a Ford and not the C h e v y.  Along with the steady rest, Ford also included a sway bar and additional frame supports among other engineering enhancements.  It’s no surprise that the Fords had a much better ride and road manners than its direct competitor.
That steady rest was deemed not necessary on the 1957 and newer Ford cars so it wasn’t seen again after 1956. As has been mentioned, that steady rest does tend to get discarded when any engine servicing is performed as it’s simply in the way.  Anytime a different engine family is installed in those particular cars, the steady rest is also eliminated.  There’s no fear for any forward movement of the engine/transmission assemblies as long as the motor and transmission mounts all remain in place.
