By Rono - 6 Years Ago
What diameter exhaust are you guys running superchargers using? I had to use Ram's Horns in my coupe which have a 2" opening, but once I get past the motor mounts I want to open it up to either 2&1/4" or 2&1/2". I'm leaning towards 2&1/2", but don't want to go too big. What are your thoughts?
I'm using 2 1/2" on a moderately powerful NA engine only for the reason that it matches the header flange and it's the smallest that universal X-pipes came in. So going off that, 2 1/2 will not hurt for yours but the rams horns are probably going to limit the potential afforded by a larger diameter. A nice taper to the larger diameter might help alleviate that.
I think Frank is using 2 1/2" on his F code.
Thanks Charlie, I'm planning on electric exhaust cutouts near the rear of the front fenders. Maybe I can transition from the 2" to 2&1/4" and then 2&1/2" at the Y pipe for the cutouts. Wish I didn't have to use the Rams Horns, but with those fat front fenders I had little or no choice for headers.
By Buzz - 6 Years Ago
on my '56 with a Paxton SN-92 I'm using custom 4-1 headers into 2 1/2 in pipe with an equalizer tube into Magna Flow mufflers - straight out the back ... looks good, sounds great
By miker - 6 Years Ago
Ron, in case you didn’t find it, here’s the link to Ted’s exhaust manifold testing, including the Rams horns with piping. Not directly comparable to a blower motor, but you might glean a little info.
http://forums.y-blocksforever.com/Topic55379.aspx
When I had the 5 lb blower motor and the Red’s headers I had 1 1/2” pipes pipes the back and cutouts ahead of the mufflers at the rear of the front wheel wells. We didn’t see a big increase with the cutouts open on the dyno. I figured it was the small outlet extension on the Red’s headers.
Mike;
Thanks for that thread! I know I'm kind of stuck with those Ram's Horns (for now). I have Magnaflow 2&1/4" mufflers and exhaust on my 56 Customline and love the sound. Good performance too Maybe I'll come up with a better idea later.
BTW, my best friend from here just moved down to Tucson in November. Do you spend your winters down there?
By Ted - 6 Years Ago
This link is from the same thread but is from page six. This particular post has graphs showing the effect of three different sized extension pipes being used with headers. http://forums.y-blocksforever.com/FindPost56021.aspx
Ron, you still at the juno address?
By LordMrFord - 6 Years Ago
60mm (2 1/4") feels little small for my high dynamic comp ratio engine. (305cid + 11.5/1 + 285°)
Mike;
Yes, but I also have a new gmail; ronosrock@gmail.com
