Search Help
http://forums.y-blocksforever.com/Topic125616.aspx
By Bjmayberry2 - 10 Years Ago
How do you search for topics? Looking for Oil MODs.
By MoonShadow - 10 Years Ago
Click on "explore" at the top left of the page. That opens a sub-menu but you will have to scroll down to see "search". If you can't scroll use the slider on the right of the sub-menu.
By NoShortcuts - 10 Years Ago
BJMayberry.  Are you all set with Chuck's explanation or do you need additional clarification?   Smile
By Ted - 10 Years Ago
Here’s a thread discussing the search forum which also includes a link that can take you directly to it.
http://forums.y-blocksforever.com/Topic110807.aspx
See if some of these help in your search.
Center cam bearing
Grooving the center cam hole in the block
Oil Flow Diagram
Pressurized rocker shafts
Pressurized rocker shaft more
Pressurized timing chain oiling
Rocker arm overflow tubes Cons
Rocker arm overflow tubes Pros
Rocker arm overflow tube More Pros
Slotting the rocker shafts for improved oiling
Timing chain oil trough
Adding lifter valley holes for camshaft oiling
Drilling additional holes for oiling and/or venting
Valley holes for aiding crankcase evacuation
