Posts: 3.3K,
Visits: 238.8K
My 57 car has a PCV valve setup installed at the rear of a late style valley cover. The stock 3 sided oil deflector is still on the underside of the cover. Regulars here or readers of Y--Block Magazine are probably aware that there can be issues with these setups. Here's another one.- I haven't driven my setup a lot & it seemed to be working reasonably well without noticeable issues. Not until the other day, when I was moving at about 50 mph, when I Iifted my foot off the accelerator, there was a fairly noisy "sucking sound". Step back on the throttle, gone, off the throttle there it was again. So, went home & lifted the hood & with the engine running, went to the the throttle off & on. There it was..the noise is in the PCV setup. It seems that oil residue had gotten into the valve area & the Grommet in the cover was lifting somewhat & causing the noise. The flange of the valley cover there, is rather shallow & that grommet, SPC 7205 does not fit tight enough "vertically" to avoid a problem when oil soaked. So, it needs a different Grommet & if the valley cover was off, I'd be looking at some type of improvement in the oil control.. My first thought is that maybe a vertical sheet metal piece hanging in front of the open side of the box, say about 1/4" out & down lower than the box might help? Suggestions?.. And for the record the valve is #2072 which was spec'd for a smaller V-6 engine.. Thanks
Visits: 22.2K
i use those oem bells and make an inline setup.cheap and easy.
Posts: 1.7K,
Visits: 340.1K
Darrell, when using one of the bells in the photo, do you used an middle 60’s threaded PCV valve usually under or at the rear of the carburetor? I have a replacement Mercury valve and am in the process of cleaning up the valley cover which has the 3 sided square box about 1-1/8” down from the cover. My cover came with bell with a 1/2” diameter tube on it. Thanks...
Visits: 22.2K
no i just use a pcv in the line itself.not threaded.i usually use a 90 degree one
Posts: 3.3K,
Visits: 238.8K
Ted: My installation is almost identical to that shown in your 1st photo. The main issue apparently is the Grommet, which is #SPC 7205. As mentioned the flange of the Valley cover is quite shallow & that grommet doesn't fit it well, as the indentation in the rubber is wider than the flange, so when wet with oil it has a tendency to " lift" enough to noisely lose crankcase vacuum. So, the question is, does the Dorman grommet #42323 fit really well into the stk cover?. Other possible grommets? Thanks...
N.B.- follow up; Also discouvered that the PCV hose I used was not rated or heavy enough for PCV vacuum. It was partly collapsing, so bought a rated hose & installed it with sealent on the existing Grommet as Ted recommended.. Haven't had an opportunity to test it further. Will advise it there is further issues.. Thanks
A thin film of RTV in the groove of the Dorman 42323 grommet before installing it in the existing valley cover hole will tighten it up in that hole and make for a better seal. Just be sure to give the sealant enough time to cure before running the engine.
