Last Active: 8 hours ago
Posts: 3.6K,
Visits: 497.5K
I use Permatex Copper RTV to glue the gasket to the cover. Nothing on the head side of the gaskets. I've used the cork gaskets and never had a problem with them. After installing the cover and running the car for awhile, just go over the nuts again to insure a tight seal.
I apply a thin coat of the RTV to the gasket, install on the cover and then turn the cover over and let the RTV set up, usually overnight. The RTV enables the gasket to be removed easily.
54 Victoria 312; 48 Ford Conv 302, 56 Bird 312 Forever Ford Midland Park, NJ
