Opinion on carbs wanted
Posted By oldcarmark 17 Years Ago
Posted 17 Years Ago
Last Active: 3 Weeks Ago
Hello All,I finally got a 57-up intake for my 56 292.I want to replace the Tea-Pot.I need a carb.I like the idea of getting an original 4150 and rebuilding it.I could also  go for one of the newer Holley 8007 390 cfm carbs.The engine is completely stock.I just want something less troublesome than what I have now.Quite a while ago someone said they got a rebuilt 8007 Holley somewhere at a real good price.55Birdman I think.Anyway looking for some opinions here.I already have the later distributor on the motor.Thanks Mark
Replies
Posted 17 Years Ago
Seems to be a misconception out there that large carburetors make an engine run richer.  In reality, the engines actually run leaner if the carb is oversized.  But I’ve had good luck with carbs up to 780 cfm driving around just fine with the Y engines.  It’s just when the secondaries are opened that may force the issue on carb sizing but with an oversized vacuum secondary carb, air flow is diminished enough that the secondaries are either late in opening or will not open at all.  It goes without saying that almost any double pumper carb will give the engine too much air when opened at too low an rpm but a vacuum secondary carb is self-compensating in this regard.  With smaller primaries, air flow or velocity through the venturies is higher which in turn gives a better throttle response at low rpms at the expense of high rpm air flow.  Atomization is also obviously better with the smaller venturies which in turn helps with fuel efficiency.
I’ve had most of the popular carbs on my 272 and the 525 cfm Road Demon Jr. is the clear winner.  I’ve run several of the ’57 ECZ carbs (390-410 cfm) and these do not have the benefit seen from the advances that have occurred in metering and circuitry that’s employed in the newer carbs and although these older carbs could be tuned to satisfy either the economy or performance characteristics desired, would not do both simultaneously in a satisfactory manner.  I did run a 500 cfm Carter for a fair amount of time and although it got good fuel economy, it was always touchy when the secondaries were first opened at the lower rpms.  Part of this is due to air leakage around the weighted secondary blades and the lack of intial fuel to compensate for this.  But beyond this, still a good all around carb.
As usual, just my two cents worth.
rgrove
Posted 17 Years Ago
Supercharged (576 reputation)Supercharged (576 reputation)Supercharged (576 reputation)Supercharged (576 reputation)Supercharged (576 reputation)Supercharged (576 reputation)Supercharged (576 reputation)Supercharged (576 reputation)Supercharged (576 reputation)
Posts: 498, Visits: 3.5K
Ted (7/19/2008)
Ted,
I didnt intend to reinforce/perpetuate that myth; sorry if it came across that way.  I certainly understand/agree with your (and others) previous explanations on bigger carbs running leaner.  I was just commenting on how my 500 cfm showed a LOT of fuel dilution on a UOA vs. the 390.  May have been as much an issue of the carb itself as the size...
I have yet to find a setup that is really all I want it to be; for starters I cant really pull much more than about 10 in hg at idle... but that is a question for another thread!
Ron Grove
Wauconda, IL
Threaded View
Threaded View
Forum Post Opinion on carbs wanted By oldcarmark ( 17 Years Ago )
Forum Post I have a 292 with a little bigger cam, blue thunder intake and ford-o... By rgrove ( 17 Years Ago )
Forum Post I'm running a 500 CFM Edelbrock on my '62 292. I'm very happy with... By YukonCor55 ( 17 Years Ago )
Forum Post [quote][b]rgrove (7/17/2008)[/b][hr]I have a 292 with a little bigger... By pegleg ( 17 Years Ago )
Forum Post Just a question.There is a 450 cfm rebuilt Holley on Ebay for a good... By oldcarmark ( 17 Years Ago )
Forum Post Seems to be a misconception out there that large carburetors make... By Ted ( 17 Years Ago )
Forum Post [quote][b]Ted (7/19/2008)[/b][hr] Seems to be a misconception out... By rgrove ( 17 Years Ago )
Forum Post Back before the dawn of time, I had two 500 Carters on a 421 Pontiac... By pegleg ( 17 Years Ago )
Forum Post I've had a similar problem with my Edelbrock 600. I have a flat spot... By charliemccraney ( 17 Years Ago )
Forum Post Not a lot of miles on it - but my 312 seems to really like the Road... By GREENBIRD56 ( 17 Years Ago )
Forum Post Hello Steve,The response is exactly what I was hoping for from... By oldcarmark ( 17 Years Ago )
Forum Post I have been thinking about getting a smaller carburetor. From what... By charliemccraney ( 17 Years Ago )
Forum Post [quote][b]charliemccraney (7/19/2008)[/b][hr]I have been thinking... By Ted ( 17 Years Ago )
Forum Post John mentioned in a old post that the Viton tipped needle and seats... By GREENBIRD56 ( 17 Years Ago )
Forum Post Thanks Steve,What is required to match manifold to carb?Boring the... By oldcarmark ( 17 Years Ago )
Forum Post With regards to grinding the manifold, if you want to get better... By Doug T ( 17 Years Ago )
Forum Post I just put an "out of the box" Holley 390 on my 272 with a 57 up... By ejstith ( 17 Years Ago )
Forum Post Thanks, Ted. If it worked on your 254 deg cam then I probably will... By charliemccraney ( 17 Years Ago )
Forum Post [quote][b]charliemccraney (7/25/2008)[/b][hr]Do the Demon carbs use... By Ted ( 17 Years Ago )
Forum Post i cannt agree more on the demon carbs they are slick and nice :D thats... By y-block don ( 17 Years Ago )
Forum Post I just put a Holley 390 on my stock as a rock 272. I put an electronic... By ejstith ( 17 Years Ago )
