Rocker arm adjustment screw
Posted By RayCarter18 11 Years Ago
RayCarter18
Supercharged (564 reputation)Supercharged (564 reputation)Supercharged (564 reputation)Supercharged (564 reputation)Supercharged (564 reputation)Supercharged (564 reputation)Supercharged (564 reputation)Supercharged (564 reputation)Supercharged (564 reputation)
Posts: 174, Visits: 1.7K
I have a 292 that some of the rocker arm adjustment screws are pretty loose when adjusting them. Is there anything I can do to make them more stiff cause I am afraid they will loosen or tighten up by Themself.
It may not be a permanent solution but, as a temporary measure you could clean the threads & apply Loctite to suspected loose ones. There has been other recent discussions on this topic here..
RayCarter18
What would be a permanent solution?
steinauge
Supercharged (366 reputation)Supercharged (366 reputation)Supercharged (366 reputation)Supercharged (366 reputation)Supercharged (366 reputation)Supercharged (366 reputation)Supercharged (366 reputation)Supercharged (366 reputation)Supercharged (366 reputation)
Posts: 143, Visits: 1.4K
Replace the interference fit adjusters with the lock nut type I reckon.
There are several fixes for the loose interference thread adjusters.  Here are just a few of them.
  1. Thoroughly clean the threads and use Loctite.
  2. Using the 0.002” oversize adjusters if you can find them.
  3. Drilling and tapping the sides of the adjusters for either 8-32 or 10-32 set screws that can be tightened into the loose adjusters.
  4. Retreading the rockers for a conventional 7/16-20 thread and using the early non-interference thread adjuster screws and jam nuts.  You may have to grind or machine a flat on top of the adjuster for the jam nuts.  (This is the one I prefer)
Here is the link to the thread from which this information came from.
http://forums.y-blocksforever.com/FindPost106489.aspx
