There are several fixes for the loose interference thread adjusters. Here are just a few of them.
- Thoroughly clean the threads and use Loctite.
- Using the 0.002” oversize adjusters if you can find them.
- Drilling and tapping the sides of the adjusters for either 8-32 or 10-32 set screws that can be tightened into the loose adjusters.
- Retreading the rockers for a conventional 7/16-20 thread and using the early non-interference thread adjuster screws and jam nuts. You may have to grind or machine a flat on top of the adjuster for the jam nuts. (This is the one I prefer)
Here is the link to the thread from which this information came from.
http://forums.y-blocksforever.com/FindPost106489.aspx
