Visits: 144
coming up with this server error thang? It ain't just you.
Posts: 3.8K,
Visits: 33.3K
Yes that's correct.At least its not just my computer.Thanks!
Visits: 506
I have one of Mr Dovers aluminum adapters works good only thing I did change is machine a longer one piece threaded nut as in longer threads into the block itself to allow for the extra thickness and added .125 to widen the nut it still fits and clears the filter much easer to tighten with out grinding on a socket or rounding off the nut flats just had to get some 1 1/4 hex stock and did it on my lathe some thing to think about adding to the kit ( HINT HINT ) well worth the extra cost as not every one has the means to fab one them self.
