A New Bellhousing Offering For The Y.
Posted By Ted 19 Years Ago
1964fordf100292
Posted 19 Years Ago
Supercharged (164 reputation)Supercharged (164 reputation)Supercharged (164 reputation)Supercharged (164 reputation)Supercharged (164 reputation)Supercharged (164 reputation)Supercharged (164 reputation)Supercharged (164 reputation)Supercharged (164 reputation)
Posts: 162, Visits: 311
is that how much the bells are???? just a tish over 400??????  that aint bad. not bad at all.
SOCAL PETE
Posted 17 Years Ago
Normally aspirated (28 reputation)Normally aspirated (28 reputation)Normally aspirated (28 reputation)Normally aspirated (28 reputation)Normally aspirated (28 reputation)Normally aspirated (28 reputation)Normally aspirated (28 reputation)Normally aspirated (28 reputation)Normally aspirated (28 reputation)
Last Active: 16 Years Ago
Posts: 28, Visits: 101
WHERE IS THIS $400 PRICE?
I see $1083.
mongo
Posted 17 Years Ago
Supercharged (391 reputation)Supercharged (391 reputation)Supercharged (391 reputation)Supercharged (391 reputation)Supercharged (391 reputation)Supercharged (391 reputation)Supercharged (391 reputation)Supercharged (391 reputation)Supercharged (391 reputation)
Last Active: 5 Months Ago
Posts: 226, Visits: 559
I have 3 blowproofs at my house , Quicktime , call me I will tell you whats involved . 931-739-0152 Dave
Po ol Davie
Sparta , Tn.
JJ
Posted 17 Years Ago
Last Active: 14 Years Ago
Posts: 28, Visits: 485
Dave,
I received my Quicktime Y-Block/T-5 Blowproof Bell Housing last week.  It's a great looking product, you did Y-Blockers a great service by providing Quicktime with the technical information on Y-Blocks to make it a good product.
Thanks again,
Jim
57FordPU
Posted 17 Years Ago
Posts: 726, Visits: 73.6K
David,
I also just received my Quick Time bell from you.  I want to echo what JJ just said and to thank you very much.
I was having difficulty last year with the tech inspectors because I didn't have a blow proof bell housing.  I had to explain that the aftermarket just didn't make one.  Now, I think they will be happy (my feet and toes too!).
I fabed up a nice scatter shield, but the Quick Time will look so much more professional.
Thanks again................
BurnsRacing981@gmail.com
Barry L
Posted 17 Years Ago
Supercharged (302 reputation)Supercharged (302 reputation)Supercharged (302 reputation)Supercharged (302 reputation)Supercharged (302 reputation)Supercharged (302 reputation)Supercharged (302 reputation)Supercharged (302 reputation)Supercharged (302 reputation)
Posts: 217, Visits: 6.7K
Has anyone seen a bellhousing that is SFI'd and will bolt a C-4 to the Y ?   Barry L
mongo
Posted 17 Years Ago
I talked with ross at Quicktime 2 weeks ago about the C4, account  they have the SFi CERTS for their cones ( 5 sizes in all ) . They can produce them. But a 25 order is the break even point. I will contact  them again if we could get 1/2 of that.  Also they make flex plates too ! Bring it in a little closer with a mini-starter.  Dave
Po ol Davie
Sparta , Tn.
LM14
Posted 17 Years Ago
Hitting on all eight cylinders (9 reputation)Hitting on all eight cylinders (9 reputation)Hitting on all eight cylinders (9 reputation)Hitting on all eight cylinders (9 reputation)Hitting on all eight cylinders (9 reputation)Hitting on all eight cylinders (9 reputation)Hitting on all eight cylinders (9 reputation)Hitting on all eight cylinders (9 reputation)Hitting on all eight cylinders (9 reputation)
Posts: 9, Visits: 48
Here's the deal on the QT bell for Y-Blocks and trucks.
Last saturday I took them my '61-64 bell to use as a jig piece. They are going to make bolt on pieces for the side mounts that will work with their existing bells. That was what they thought first after looking at the stock bell last weekend.
Their combination uses the clutch/pressure plate and t/o bearing that matches the tranny (IE: T-5 Mustang tranny would use all 5.0 stuff). The starter is an FE starter and the flywheel is from a company they work with. The flywheel is drilled Y-block and uses 2 or 3 bolt patterns for the pressure plate.
That was first blush last weekend. Hope that helps,
SPark
1964fordf100292
Posted 17 Years Ago
hey guys. I have another posting for this topic on ford enthusiasts.  Here's the link: http://www.ford-trucks.com/forums/877744-aftermarket-5spd-updated-info.html
Posted 17 Years Ago
Last Active: 11 hours ago
1964fordf100292 (9/27/2009)
I tried bringing up the FTE forums but they are not very dial up friendly.  After several minutes I gave up and found I was being loaded up with advertising and tracking cookies.  Can you give a quick summary of what’s being said?
