Industrial Y-Block
Posted By Daddys_Barn 13 Years Ago
Posted 13 Years Ago
Posts: 7.5K, Visits: 205.9K
John Mummert (2/28/2013)
....Heads might have had sodium filled exhaust valves. Not sure what year they were introduced. The oldest heads I've seen with sodium valves were 1959. They were common in -471 and C1TE heads.
If it has ECR heads it is HD truck or industrial. I've never seen a set of these heads in person to see if they had sodium valves.
John. The oldest heads I currently have with the sodium exhaust valves are pairs of ECR-A’s and ECR-C’s. Based on the date codes, they are 1955/1956 vintage.
Posted 13 Years Ago
Posts: 3.7K, Visits: 323.4K
Ted:
I didn't mean to say that '57 heads couldn't have come with sodium valves, I meant to say that they weren't put in G heads, but in industrial casting numbered heads. Incidentally, the sodium version of the 471 heads had B9TE casting numbers.
Posted 13 Years Ago
John (Hoosier). No problem. I was answering John (Mummert) in that the oldest sodium exhaust valves he had seen in Y heads was for the ’59 models. I have had cylinder heads with sodium exhaust valves going back to at least to 1955 for the Y engines just as a matter of general information.
Y block Billy
Posted 13 Years Ago
Posts: 1.6K, Visits: 5.2K
I have a pair of ECR-D I think with the sodium valves and these heads have the smallest combustion chamber I have ever seen, almost no step from head surface to chamber. Do you know what the combustion chamber size is on your ECR heads Ted?
55 Vicky & customline
John Mummert
Posted 13 Years Ago
Posts: 917, Visits: 7.5K
Heres a picture of what appears to be a 1 bbl carb on a Y-Block Onan generator. Look as like an adapter on a 57 and later 2 bbl manifoldhttp://forums.y-blocksforever.com/Uploads/Images/1b7c8a1c-e709-465b-874b-aadc.jpg
http://ford-y-block.com
Posted 13 Years Ago
In reference to sodium filled exhaust valves in the truck heads, I’ve come across an earlier model Y head with sodium filled valves than what’s posted above. This one is 1954 vintage with EBZ-L casting numbers.
