Visits: 137.8K
Mike, just found it in my junk mail folder. Check you e mail.
Visits: 1.0K
You mentioned extra parts. Do you have any planetary gears laying around? I've been told the planetary gears are the same as a T-86 except there are 4 instead of 4. If I can find some I'll have a complete T-89 (truck version).
E.J. in Havana FL
Last Active: 14 Years Ago
Visits: 3
do you still have that overdrive transmission?
Visits: 323.8K
Kenny: Look a couple of posts down. Pegleg still has his T85 for sale.
Visits: 1.0K
Slumlord, again, in that box of parts do you have a 4 planetary gear set?
E.J. in Havana FL
Visits: 137.8K
Sorry I missd your question. Sold all the spare parts with the transmission.
Visits: 1.0K
iowa fords (10/25/2011) I paid $200. for an overdrive trans this summer, it had everything I need to installIf you got a good T-85 for $200 you stole it...... A hell of a deal...
E.J. in Havana FL
Visits: 318
I bought a rebuilt with an 11" clutch disc from an older gentleman last Summer for $120.00 so they are out there a guy just has to look hard enough. This one sat around 30 years after being Professionally rebuilt.
312T85Bird
What?
Visits: 318
HOORAH>RIGHT ON< KEEP THEM THE WAY THEY CAME AND HOW THEY BELONG. IT MAY COST MORE THEN BUTCHERING THEM BUT THAT IS WHY EVERYONE DOES NOT HAVE ONE!!!
312T85Bird
What?
Visits: 318
Do the same as square gear drivers did for years, bring the gears up to match the speed (RPM & MPH) and it will slide into 1st and then let the clutch out. Big rig drivers for years only used the clutch to stop and start and shifted with R's the rest of the time.
With a little b practice you will be a pro,
312T85Bird
What?
