What 4 barrels do you "daily drivers" run?
Posted By Daniel Jessup 18 Years Ago
63 Red Stake Bed
Posted 18 Years Ago
Supercharged (194 reputation)Supercharged (194 reputation)Supercharged (194 reputation)Supercharged (194 reputation)Supercharged (194 reputation)Supercharged (194 reputation)Supercharged (194 reputation)Supercharged (194 reputation)Supercharged (194 reputation)
Last Active: 14 Years Ago
Posts: 193, Visits: 594
oK, So  I've had 2100, holley 2300, Autolite 4100 1.08, & 4100 1.12, & 1.08 with ported secondaries, early q-jet, & am currently testing an early rochester 4-G on my f100.
I am pleasantly surprised at the top end with the Autolite 1.12, but of course dissapointed at the throttle response & low end.
I belive the throttle response on the tiny rochester 4G will be impressive once I get the linkage road worthy to test.  It makes me want to re-visit the Q-Jet, this time with a better test specimine, armed with my box of jets & meetering rods & hangers.
In street trim the y seems to love the velocity of the small venturi, but the funny ports seem to like the flow capcity of a larger carb... Maybe it will be a best of both worlds??
Or am I just bench racing again????
yfreak57
Posted 18 Years Ago
Supercharged (103 reputation)Supercharged (103 reputation)Supercharged (103 reputation)Supercharged (103 reputation)Supercharged (103 reputation)Supercharged (103 reputation)Supercharged (103 reputation)Supercharged (103 reputation)Supercharged (103 reputation)
Posts: 100, Visits: 1.0K
Autolite 2100, Holley 600 and now Street Demon "something"...Tongue
Still adjusting and tuning.
-jyrki from Finland-
www.hollowheads.net
LordMrFord
Posted 18 Years Ago
Posts: 687, Visits: 9.3K
I have tested Motorcraft 2100, Carter AVS, Quadrajet and 600cfm Holley.
Hyvinkää, FI
Pete 55Tbird
Posted 18 Years Ago
Posts: 721, Visits: 93.2K
I have a 57 312 with an air cooled FOM, mild cam and haved used a holley 4160 model 1850a, 600 CFM for a lot of years and I like it a lot. Pete
Y block Billy
Posted 18 Years Ago
Posts: 1.6K, Visits: 5.2K
Having tried most other than the demon, here is my 2 cents.
Edelbrock: starts like crap, need to pump the hell out of it and turn car over several times before starting (hard on starters wires cylinoids and doesn't look good in front of people when hard starting) although once running doesn't perform too bad good and tourquey but poor fuel economy. Every edelbrock on anything ever run acted the same way.
Holley: Best starting, let car sit 6 months and just touch the key and the car is running in first revolution of cranking over. excellent all around performance but they are sensitive and need regular maintenance and tuning. moderate economy.
4100: Starts almost as good as the holley, sometimes have to give one or two pumps and car is running within one or two revolutions of cranking over. Smoothest operation, best economy, Best fuel atomization of any carb ever built, least maintenance, can't leak. The number one choice for all around carb.
BG Race demon: Coming later at a dragstrip near you.
55 Vicky & customline
bird55
Posted 18 Years Ago
Posts: 1.1K, Visits: 58.8K
eldebrock 600
Posted 18 Years Ago
Posts: 4.6K, Visits: 37.9K
I run a 650 Holley double pumper with a McCullouch supercharger and cam to match. Probably over carb'd but works ok for now. Chuck in NH
PWH42
Posted 18 Years Ago
Posts: 854, Visits: 6.0K
57 T-Bird Holley
Paul,
Boonville,MO
Posted 18 Years Ago
Posts: 6.1K, Visits: 442.2K
Edelbrock 600.
Posted 18 Years Ago
Lincoln Teapot (Holley 4000)
