Lawn Mowers and ethanol
Posted By charliemccraney 15 Years Ago
Glen Henderson
Posted 15 Years Ago
Posts: 1.4K, Visits: 7.5K
The ethanol causes mosture to collect in the tank, also just as it will eat up the old type of needle valves in carbs, it will affect any rubber component in the fuel system. I have a Stile chainsaw that had to have all the rubber lines and carb diaphram replace. The guy at the saw shop told me about the Sea Foam helping to prevent mosture and deterioration of rubber components. He said that he has seen a huge increase in fuel system problems with ethanol.
Glen Henderson
Freedom is not Free
Letohatchee, AL
Posted 15 Years Ago
There is a warning on the mower to not use anything more than 10% ethanol. I guess an ethanol test kit will be worth while.
From my research, much of the real bad stuff seems to happen on two cycle engines because the oil is mixed with the gas and apparently does not play well with the ethanol. But across the board, they seem to run hotter and since they are only air cooled, it can cause problems. And also, the issues with the gaskets and hoses in the fuel system. I just don't understand why they don't use gaskets and hoses that are safe with ethanol. It's not like it just became known yesterday that the old materials do not handle it well.
The Master Cylinder
Posted 15 Years Ago
Posts: 974, Visits: 6.2K
charliemccraney (7/18/2011)
I just don't understand why they don't use gsaskets and hoses that are safe with ethanol. It's not like it just became known yesterday that the old materials do not handlke it well.
Because that's too logical??
Posted 15 Years Ago
Posts: 3.7K, Visits: 498.2K
I got a push motor with a Briggs & Stratton ( 4 cycle) engine and have used nothing but the ethonol blend. 10 years old and no problems with the engine. Chassis is wearing out though.
yehaabill
Posted 15 Years Ago
Supercharged (468 reputation)Supercharged (468 reputation)Supercharged (468 reputation)Supercharged (468 reputation)Supercharged (468 reputation)Supercharged (468 reputation)Supercharged (468 reputation)Supercharged (468 reputation)Supercharged (468 reputation)
Posts: 426, Visits: 1.4K
Y-Guys:   Good a.m. My 2 cents, since my shop works on atv's, dirt bikes 2&4 strokes.
          It may have something to do with our humidity down here, but if a bike
          or atv "sits" in-active for 6 weeks or more, with gas in the carb, it usually
          will not start. We can pull the float bowl and it will be green with "hair"!
          growing out of the jets.(I'll get my son to post a few pictures later)
             There are several additives that help, but just turning the fuel off and
         letting the carb go dry seems to help.
             Each year, our tech schools have contests to judge students on their
         learning experiences and I'm usually one of the judges for the small engine
         section. There are "reps" there from John Deere, Husqvarna, Echo, and others
         showing off their new products. This year the John Deere rep and I were
         talking about the ethanol problem(as I write this congress has approved a 15%
         increase) he told me John Deere had sold more carb's this year than they had
         in the past 5 yrs combined!
            You may not have a problem if you use the equiptment on a regular basis
         but it's a MAJOR problem in my area.
                                                      Bill
Bill
Pelham,Al
Y block Billy
Posted 15 Years Ago
Posts: 1.6K, Visits: 5.2K
Agree with Yehaa Bill, I have worked on many small engines and I have an 048 stihl chainsaw that I had for 30 years, never had a problem until the ethanol, it started starving for fuel, it would idle fine but when you gave it throttle it wasn't taking it, reached my finger in the tank and pulled the fuel line and it was mush so everytime you pulled the trigger it would collapse the hose. the new hose I ordered came through with stiff rubber rings around it like a ribbed condom.
But for any mowers and small engines you run occasionally, using AVGAS is cheap insurance. I now use it for anything I have sitting around. Little more expensive, but no problems when you need it in a hurry and don't have time to repair things before using them.
Just my 2 cents
55 Vicky & customline
