Wanted-Granada spindles, rotors etc.
Posted By Missouri Mike 14 Years Ago
Missouri Mike
Posted 14 Years Ago
Posts: 210, Visits: 1.2K
Mark-
I couldn't get anything to come up on number 330578871122.
Mike
I'd rather be lucky than good.................
    but good ain't bad!!
Posted 14 Years Ago
Last Active: 7 days ago
Should have been 330576871122.I edited the original post too.
old cars
Posted 14 Years Ago
Posts: 18, Visits: 1.3K
Jeff did you have to do any mods.or is it a bolt on. What parts did you use?  ,Thanks
Missouri Mike
Posted 14 Years Ago
Mark-
Thanks a lot!  Believe I'll be buying a master/booster from Oldirishdave.  Was very pleasantly surprised to see the chrome version was only $15 more. Hadn't even considered chrome but for 15 bucks you can't beat it
I had looked at some other websites and they were wanting almost $100 more!
I really appreciate your help, because it's so reassuring to deal with someone that others have dealt with and had a positive experience.
Missouri Mike
Stay off the Missouri River for the next month or so.
Posted 14 Years Ago
Mike! As I mentioned,phone him direct.Dont buy it on Ebay and you may be even more pleasentley surprised at the price.Good guy.Enjoys talking to people.You might bwant to look at his other items too.I used his adjustable prop valve on mine.I mounted it on the fram under the steering box and screwed the rear steel line into it and the brought the line from the master down to the valve.You can reach it under the box but no one  can see it.As mentioned others prefer the factory style prop valve which Dave also has.I did NOT use any residual pressure valves as I understand they are used where the master is under the floor.
