Frost plugs and PCV conversion
Posted By scott5560 15 Years Ago
scott5560
Posted 15 Years Ago
Supercharged (77 reputation)Supercharged (77 reputation)Supercharged (77 reputation)Supercharged (77 reputation)Supercharged (77 reputation)Supercharged (77 reputation)Supercharged (77 reputation)Supercharged (77 reputation)Supercharged (77 reputation)
Posts: 66, Visits: 354
Prepping my block for 292 build after cleaning.  I bought new steel frost plugs and oil gallery plug kit from Ebay.  Do you need to put any sealer on the frost plugs when driven in?
And I ordered a Holley 94 1" aluminum carb spacer to put a fitting in for PCV conversion.  Does it matter what size the through hole is?  Ie. for affecting idle and vacuum or is that regulated by the PCV valve itself.  I am going to get original steel one for 60's era trucks 292 and drill and tap the block behind the valley pan.
Thanks guys.
