moose19sk
Visits: 54
Will some later wheels fit on a 55 ford customline like a 15x7 or what else will that may fit from a mustang or ranger or thunderbird looking to use like a 215x75x15 tire. Thanks Steve
junkyardjeff
Visits: 3.4K
I had a pair of 71 country squire 7 inch rims on the back of my 55 but I have a maverick rear end in it which might be a little narrower.
moose19sk
Visits: 54
Is there any wider wheels i can use? Thanks Steve
crenwelge
Last Active: 7 Months Ago
Visits: 1.7K
I have used various 15" wheels on a 56 Ford which has the same dimensions as a 55 without a problem. However, I don't remember where the 15" came from. Some of them have too much back set and the tire hit the upper ball joint in front.
Kenneth
Fredricksburg, Texas
YukonCor55
Last Active: 14 Years Ago
Visits: 161
Steve, I'm running 15X6 Cragar chrome smoothies with BFG 215/70/15's on my 55 Ranch Wagon. The tires are the perfect width for the rims. All suspension geometry is stock and I have no clearance problems at all.
A.J.South Jersey SMSgt USAF Retired 1955 Ford Ranch Wagon & a couple of old guitars...Life's Good!
Jerome
Visits: 1.0K
Steve, Factory wheels for my 56 Fairlane were 15x5.5 rims on 7:10x15" 27.5" diameter tires. I went with custom 15x7 Cragar rims on 3.75" back space in front with 215/60R-15 H speed rated 25.5" diameter tires. The smaller diameter was required to clear my fenderwell exit headers. For the rear, I went with custom 15x8 Cragar rims on 5" back space with P255/60R-15 T speed rated Dunlop G/T 27" diameter tires. I had to replace all rear leaf spring bushings, fab a panhard rod and still had to trim some projecting surfaces to keep the rear tires from rubbing during turns and acceleration. There just isn't much room in them rear fenderwells. Jerome
moose19sk
Visits: 54
Thanks for the info that helps out a lot now i can shop around and have an idea what i can use. I just sold a 59 studebaker lark and had the same problem they just didn't have much room back in the day. Thanks Steve
Canadian Hot Rodder
Visits: 1.3K
Yes they will fit. I am running 16" x 7" 2000 Ford Explorer wheels on my 56 along with 215 R 60's up front and 225 R 60's out back. The only thing that was tight was when I still had my front drum brackes. I had to use a 1/4 wheel spacer to keep the tire from rubbing on the upper ball joint. When I switched to Granada disc brakes I no longer needed the spacer. In the rear I have about 3/4" clearance on each side of the tire, which fills up the rear wheel well nicely. I believe the 55 wheel wells are the same and also the Ranger wheels are the same offset as the Explorer, even the 15" sizes.
rick55
Visits: 4.4K
The only problem with using late model wheels whether the backspacing is correct or not is that the wheels are designed to fit on the larger late model stub axle. This means that the bolts take all the forces that are applied to the wheels when travelling.
I would suggest getting a machine shop to make a collar to fit over the hub and properly locate the wheel on the hub.
I have actually seen a wheel cracked all the way round the bolt holes of an late model aftermarket steel wheel that was fitted to an earlier hub. The guy did used to drive like there was no tomorrow though - may have contributed.
What are all your thoughts?
Rick - West Australia Do Y Blocks Downunder run upside down? Gravity Sucks!!
Canadian Hot Rodder
Visits: 1.3K
Rick, That may be possible but I can attest that I have had no problems what so ever with my wheels and I have been running them for at least 6 years. Also anyone who knows me will attest that I drive mine like I stole it! I think I am on my 4th set of rear tires and 3rd trnasmission rebuild!!!
